Old Aug 21, 2014, 03:21 AM
park aviator's Avatar
Australia, NSW, McGraths Hill
Joined Mar 2008
all foam C130
Hi guys though id post a pic of my new c130 all wire cut foam covered in water based polyurethane and brown paper specs are 65 inch wingspan 4emax brushless motors 4 turnigy plush 30 amp esc just finishing of the beast maybe week of work to go. Cheers Tod.
park aviator is offline Find More Posts by park aviator
Old Aug 21, 2014, 04:03 AM
Marty Petri Sr.
mbpetri's Avatar
Thailand, Uttaradit, Bo Thong
Joined Jun 2007
Looks good Tod, any idea what your AUW will be?
Marty
mbpetri is offline Find More Posts by mbpetri
Old Aug 21, 2014, 04:31 AM
Joined Mar 2008
Going to use 2 2200 3 cell lipo battery's 1 for inboard motors and 1 for the two outboard motors she should be around 2350 to 2400 grams with paint on all up weight does this sound ok
Old Aug 21, 2014, 05:19 AM
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
That looks sweet! Nice big bird.. Big enuf' to have presance and small enuf' to transport!
How will you do the motor signals? 4-into-2-into-1 with Y-leads?
G'luck with maiden!
George
georgy is online now Find More Posts by georgy
Old Aug 21, 2014, 05:42 AM
Joined Mar 2008
I've got 3 wye leads all four into one but two motors to 1 battery and other 2 motors into 2nd battery make sence o and a ubec all positive esc wires disconnected
Old Aug 21, 2014, 05:49 AM
Joined Mar 2008
Going to paint her up as a RAAF C130 E model ive got 7x4 4 bkade propellers as well here is a pic of the full size
Old Aug 21, 2014, 06:27 AM
Joined Mar 2008
Nacelles now glued on waiting for them to dry .
Old Aug 21, 2014, 06:51 AM
georgy's Avatar
Joined Jan 2012
Those nacelles looks realy good! Are they also hot-wired and sanded? They look factory made! VERRY NICE! Those 4-bladers are also a nice touch!
Old Aug 21, 2014, 07:20 AM
Joined Mar 2008
I got the nacelles from park flyer plastics in the US
Old Aug 22, 2014, 01:31 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Great workmanship!
What is your sequence of applying water based polyurethane and brown paper to the foam?
Do you wet the brown paper with the PU first?
djacob7 is offline Find More Posts by djacob7
Old Aug 22, 2014, 02:37 AM
Joined Mar 2008
You need unwaxed brown paper and small paint roller wet paper both sides so it goes soaked and put a bit on model then lay it on model and smooth out
Old Aug 22, 2014, 10:29 PM
Joined Mar 2008
Ok guy's she is ready for paint tomorrow all up weight should be 1350 grams or 5.1 pounds
Old Aug 23, 2014, 12:11 AM
Fremont, CA
Joined Jan 2009
This really looks exciting - anticipating the maiden.
Old Aug 27, 2014, 12:56 AM
Joined Mar 2008
Painting has been finished now onto making the decals
Discussion 64 inch all eps c130 herc park aviator RC Airliners (Commercial, Cargo, Troop Carrier) 24 Sep 17, 2014 05:29 PM
Discussion Foam c130 kits park aviator Australia 23 Aug 27, 2014 06:42 AM
Foam C130 Hercules jblosser Foamies (Kits) 41 Feb 04, 2010 11:23 PM
Foam C130 jblosser Foamies (Kits) 3 Feb 04, 2010 11:22 PM
72" span - Foam C130 Hercules Vogon Foamies (Kits) 8 Feb 04, 2010 11:20 PM
