Old May 22, 2014, 11:41 PM
DeXX's Avatar
Croatia
Joined Nov 2009
Build Log
12 motors DeX Nuke
Well, a new model is here... DeX Nuke ...named after the symbol
6/12 motor option...
it is made for max 8'' props
420mm from shaft to shaft diameter, 470mm outside diameter
hole diameter beneath cover is 135mm
plenty of space...
hull weight 255g
cover weight 25g
carbon buckles 2,5g
total weight of the model on the photos rounded up to a gram ... 283g
landing gear is in the process I do not know the weight of the landing gear at the moment...
model is made from one piece... that would mean that connecting the upper and the lower half of the model is made wet-on-wet and that makes a perfect joint... a one piece model
I just love the aggressive look of the model
and a few more pictures...
DeXX is offline Find More Posts by DeXX
Old May 22, 2014, 11:55 PM
Australia, SA, Adelaide
Joined Jun 2013
Incredible workmanship.
Looking forward to some video of it in the air. Its aggressive profile should look fantastic.
Scottapotamas is offline Find More Posts by Scottapotamas
Old May 23, 2014, 12:35 AM
Happy Holidays
AnthonysQuad's Avatar
Joined Jan 2013
Nice job I like to see different designs.
AnthonysQuad is offline Find More Posts by AnthonysQuad
Old May 23, 2014, 09:15 AM
DeXX's Avatar
Croatia
Joined Nov 2009
Thank you!
my goal was to create something with unique shape, light while at the same time very sturdy one piece model....
I can not wait to fly it... but I'm still at motor selection at the moment ....
Old May 23, 2014, 09:49 AM
Pants first, then shoes
Joined Jan 2011
Dex, what sort of setup do you have for mounting a gimbal on that and/or landing gear ?
Stacky is offline Find More Posts by Stacky
Old May 23, 2014, 10:22 AM
DeXX's Avatar
Croatia
Joined Nov 2009
landing gear will be at the same time a gimbal mount... it will be mounted with 4 screws from below
original idea was that the landing gear is only one piece but that would define a fixed height which is not good for different camera and gimbal size...
so that the final solution is in three parts... one mild M shape which fits the curve of the hull and two skis at the bottom of M....
M shape will be cut to the required length depending on the camera and gimbal size... from gopro to nex5... that is the plan
Old May 23, 2014, 10:43 AM
The Netherlands, NH, Amsterdam
Joined Aug 2007
Great, now I have to sell my Dex50.
Stunning!
drkdgglr is offline Find More Posts by drkdgglr
Old May 23, 2014, 04:30 PM
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
absolutely beautiful as always man. I love nontraditional hexa designs!
Send me one. thanks
daign is offline Find More Posts by daign
Old May 23, 2014, 07:20 PM
DeXX's Avatar
Croatia
Joined Nov 2009
Stunning!
You've got to have them all !
Old May 23, 2014, 07:31 PM
DJI SUPPORT / TESTING
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Incredible work of art..just awesome!
blade strike is online now Find More Posts by blade strike
Site Sponsor
Latest blog entry: S900 H3-3D Mount
Old May 23, 2014, 07:32 PM
DeXX's Avatar
Croatia
Joined Nov 2009
Send me one. thanks
thanks, I wanted something visually really different.....
I am pleased how the idea has been realized... and model will very soon be fully ready for production
just send me your address
Old May 24, 2014, 03:53 AM
RTFM // copter damaged
warthox's Avatar
Joined Aug 2009
looks cool
reminds me on my first hexa builds 3 years ago.
the centerpart look pretty big? any picture for size comparison?
is it possible build the frame with a matt finish?
warthox is offline Find More Posts by warthox
Old May 24, 2014, 02:00 PM
DeXX's Avatar
Croatia
Joined Nov 2009
Originally Posted by warthox View Post
looks cool
Thanks!
the centerpart has a diameter of 210mm and a height of 75mm...
molds are very shiny so all the casts are shiny when they come out from the mold...
full matt finish I think it is not possible but i can achieve semi-matt surface with very fine waterproof sandpaper if it will be necessary
here are some picture for comparison Nuke with Mini and 50cm Quad side by side and one on top of another
Old Jul 21, 2014, 08:39 AM
DeXX's Avatar
Croatia
Joined Nov 2009
Build log
I have some free time for myself so I'll make this into a build log....
in the end result should be 12 motors Nuke with a 3 axis gimbal and Nex5N FPV machine
the biggest headache were the motors because I had a couple of criteria when selecting motors and here they are sorted by relevance
1. they must be completely black(and it is very problematic to find)
2. 2205 size
3. weight 25g or below per motor
4. thrust about 600g per motor
After a long search for a suitable motors I chose emax GT2205/22 : http://www.emaxmodel.com/views.asp?hw_id=14
because they were the only ones meeting the criteria on paper and they have the manufacturer sticker which is easily removable
but the enthusiasm was quickly down after receiving the motors... first thing I've noticed were very bad/ugly windings
test showed only 430g - 470g thrust with different 8'' blades
so after trying several types of wire thickness and turns... the best result was with 20 turns of 0,375mm wire
and the motor produces 650g of thrust with 8040 prop
my rewound motors are up and the original motors are down on the photo
so I finally have motors that meet all the criteria above and they sit nice and flat on the model arms
I just need a little bit of rewhining to finish all 12 motors.... until tomorrow
Old Jul 22, 2014, 10:33 AM
DeXX's Avatar
Croatia
Joined Nov 2009
all 12 motors are done, I just need to solder wires....
For Sale (6) 6" & (6) 12" Futaba Extensions TGKconnectors Aircraft - General - Radio Equipment (FS/W) 4 Apr 13, 2014 01:50 AM
Sold Futaba Extensions 6", 12", 18" TGKconnectors Aircraft - General - Radio Equipment (FS/W) 3 Nov 14, 2013 10:55 PM
For Sale Micro 3D Airplane BNF 12" Span, 22.6 gm RTF- Great for Indoor 3D Flying scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Nov 11, 2013 04:22 PM
Sold NIB Blue box 1:6 (12") F-18 Pilot figure with Stand and Accessories x3dflyer Aircraft - General - Miscellaneous (FS/W) 0 Oct 25, 2013 02:15 PM
Sold New German Pilot for 1/6 Warbirds for only $12 unclegeorge Aircraft - Fuel - Airplanes (FS/W) 0 Sep 21, 2013 04:40 PM
