Old Jan 24, 2014, 05:47 AM
Centreville,VA,USA
Joined Apr 2001
Start of Micro I-16
I've made a WWII VVS 32" WS and a Spanish Civil War, Republican 28" WS version of the I-16 from the same free paper model plan the Modele Kartonowe Polikarpov I-16 in 1:33 scale now it's time to do a 14.5" WS Micro 1-16.
I'm not sure what scheme I'll do though it will be Russian and winter one maybe the same black nose as my 32" span or a Red 41 or Red 21. I'm leaning toward Red 21.
I 've done the paper mock up. My buddy Speedy01, Gene enlarged the paper plan to a 14.5" WS for me. Thanks Gene.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jan 24, 2014, 08:07 AM
Isaiah 40:31
rc capo's Avatar
West Palm Beach, FL
Joined Jun 2000
Very cool. I saw pretty cool flying sequence of a 1-16 in a Korean war movie "My Way". Yes, it was probably CGI, still was neat to see a correct aircraft flying @ the correct timeline. Looks great.
rc
rc capo is offline Find More Posts by rc capo
Old Jan 24, 2014, 08:11 AM
Beam me up Scotty!
Virginian's Avatar
United States, VA
Joined Nov 2012
Very cool! I look forward to your completion.
Virginian is offline Find More Posts by Virginian
Old Jan 24, 2014, 08:34 AM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Pete, you beat me to it. The I-16 is on my short list! I have been eyeing it for years. Oh well! I will look forward to your model.
gklein is online now Find More Posts by gklein
Old Jan 24, 2014, 08:38 AM
Gulf Breeze, FL
Joined Jul 2006
Wow - that big one is a big one.
Why did you select 14.5?
This will be a beauty!
Gene K
P.S. Can you post links to your other RCG I-16 builds, please?
speedy01 is offline Find More Posts by speedy01
Old Jan 24, 2014, 09:13 AM
Centreville,VA,USA
Joined Apr 2001
Thanks to all.
The I-16 like a WWI model can be tricky to fly since it's got such a short nose area but I think this stubby fighter is different and cool.
Gene, You're killing me
I thought since the 14.5"WS work well on the Micro WWI planes I/we've done I'd give this mono wing 1939 to WWII bird a try. Using the PZ P-51 motor/gearbox set up and a std AR6400 brick with one additional servo for ailerons. I usually do 16" WS for Micro WWII builds as I know this works well. I may need to go with a J3 motor gearbox to keep the wing loading down though we'll see.
I think I posted a ton of how to's on both. The larger version 32"WS big one, I think I did it in the WWII scratch builds Forum. I built it maybe 9 or 10 years ago, I can't remember. The Spanish one I did maybe 3 or 4 or so years ago. I thinki I posted it as a Mini I-16 build in the Foam Scratch builds.
Pete
Old Jan 24, 2014, 09:56 AM
Gulf Breeze, FL
Joined Jul 2006
That's a LONG-running "short" list, Gary:
http://www.rcgroups.com/forums/showp...&postcount=32;)
Gene K
Old Jan 24, 2014, 10:01 AM
Gulf Breeze, FL
Joined Jul 2006
The I-16 like a WWI model can be tricky to fly ....
I was contemplating (I'm good at that) a larger model using the innards of my crashed Gee Bee since they're "somewhat" similar shape wise. Around 20" WS.
Mission accomplished.
I think I posted a ton of how to's on both [large I-16s].
Yes - they're easy to find using RCG's excellent search engine.
Gene K
Old Jan 24, 2014, 12:37 PM
Canada
Joined Nov 2000
That is Great! work.
Love the shape of those things. A Russian Gee Bee.. sort of.
I was looking for a card model of the !-16 for a bit,.
Ever since seeing the SMEFF flat foamy 'combat' version fly .. which it does, Very well.
Ooops.. I do have it in 1:33 and 1:48
Clearly wayyy more stuff than brain capacity.
Bare is offline Find More Posts by Bare
Old Jan 24, 2014, 01:05 PM
Centreville,VA,USA
Joined Apr 2001
Bare,
Glad you have it. It's a very easy conversion from paper to Depron foam. I recommend you do a sized up paper mock up to ensure how it will go together and look at whatever size you are thinking.
http://www.modele-kartonowe.com/i-16_1_48/index.html
Here's the same bird in Fin scheme.
Pete
Old Jan 24, 2014, 01:49 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Pete -
The I-16 is in my "as soon as all the other planes on my build list are done" queue.
I love any plane that's fatter than a Brewster Buffalo!!
You, speedy01 and Jin have me converted from WWII and Korean-era planes to WWI - I'm starting to get dizzy!!
356Jim is online now Find More Posts by 356Jim
Old Jan 24, 2014, 02:33 PM
Centreville,VA,USA
Joined Apr 2001
We all know what you mean Jim. Case in point my work table still has an unfinished D.VIII on it. I got into the WWI birds and got the bug. I just wanted to step out for a WWII build of one of my favorite subjects. I like it because it's not so often done lots of history, schemes and the paper conversion to Depron is fairly simple yet can look the part.
Pete
Old Jan 24, 2014, 05:01 PM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Gene K
Guilty!!!!!
Old Jan 24, 2014, 05:38 PM
Canada
Joined Nov 2000
Thank you for the link. it is appreciated.
I had the "Hero General" versions :-)
I was considering 1:18 (20") Or 1:16 (22") scale ?. Hex 10 gm motor / 300 mah 2s battery, 3 ish..to less than 4 ounces.. he says hopefully.
I'm not quite ready for 1;24 th size micro builds, as My build skills deteriorate proportionally to size reduction
Excellent suggestion/advise, to build the thing first as a Card model.
What thickness depron would you suggest? 1 or 3mm being locally available and do I needs use tissue or perhaps simply 'lighter' printer paper.. assuming such is reasonably available in these days of 20 lb 'normal' stuff.
Old Jan 24, 2014, 07:02 PM
Arrowhead
Joined Dec 2010
Awesome! The I-16 has tons of character. Would love to add one to my hangar at some point!
CF105 is offline Find More Posts by CF105
Sold 808 Micro Camera - Version #16 with lense D fdaremi Aircraft - Electric - Multirotor (FS/W) 7 Nov 16, 2013 06:32 AM
Discussion 808 #16 micro fpv plloppii FPV Talk 3 Nov 03, 2013 05:10 PM
Sold Mini DVR 808 #16 V2 -Lens B Car Key Chain Micro Camera HD quadcopter007fpv FPV Equipment (FS/W) 0 Oct 07, 2013 12:05 AM
ECO 16 Form Start To Maybe End mlangman Electric Heli Talk 45 Jun 01, 2003 11:45 PM
Weird start up.Mega 16/15/5,any answers plese? bipeflyer Power Systems 4 Apr 14, 2003 12:18 AM
