Old Mar 27, 2013, 09:48 AM
ServoCity's Avatar
United States, KS, Winfield
Joined Jun 2011
Link
HSR-1425CR continuous rotation servos back in stock!
HSR-1425CR Servos are back in stock at ServoCity {$16.99}
http://www.servocity.com/html/hsr-14...s_rotatio.html
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-4F to +140F)
Operating Speed (4.8V): 44 RPM at no load
Operating Speed (6.0V): 52 RPM at no load
Operating Torque (4.8V): 38.8 oz-in (2.8 kg-cm)
Operating Torque (6.0V): 42 oz-in (3.1 kg-cm)
360 Modifiable: Completed
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Motor Type: Brushed
Potentiometer Drive: No Potentiometer
Bearing Type: Dual Ball Bearing MR106
Gear Type: Nylon Gears
Connector Wire Length: 7" (178mm)
Dimensions: 1.59" x 0.77"x 1.44" (40.6 x 19.8 x 36.6mm)
Weight: 1.47oz (41.7g)
Bolt on one of our aluminum servo hubs and then choose one of our many wheels to attach.
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
Discussion 9XR Mode 1 Back in stock at Global Warehouse mnemennth Hot Online Deals 5 Mar 09, 2013 12:37 AM
Discussion OrangeRX DSMX/DSM2 2.4Ghz Transmitter Module (JR/Turnigy) BACK IN STOCK AT HK! mnemennth Hot Online Deals 1 Feb 24, 2013 08:07 PM
Yippee! HSR-1425CR Servos are back in stock at ServoCity!! ServoCity ServoCity.com 0 Oct 19, 2011 03:33 PM
Auto Rotation Hub and many others are back in stock. Andy N Product Announcements 0 Jul 07, 2004 08:17 PM
