Old Dec 24, 2012, 12:01 PM
United States, TX, Austin
Joined Jan 2012
Equipment for charging 4 1 cell LIPOs in parallel
I have been reading through these threads for several hours and honestly I am more confused than when I started.
Here is what I would like to accomplish. I want to be able to charge up to 4 single cell lipo batteries at the same time. However, I would like to do this in a way that will not overcharge the batteries if I leave them on the charger too long since I seem to do this too often.
What I think I may have learned from my reading thus far is that I will need a charger, an AC adapter and some type of harness to charge the batteries in parallel.
I have seen several threads recommending this charger but I am not really sure if it is a fit for my needs. I have no idea what kind of harness would be needed to charge 4 lipos or where I would get it.
I am on a budget but would be willing to spend a more to get something that works well and will last.
Any advice is appreciated.
dalto is offline Find More Posts by dalto
Old Dec 24, 2012, 12:08 PM
So. Cal.
Any good quality lipoly charger will be capable of accomplishing your goal.
A nice selection of parallel charging adapters can be found here: http://www.progressiverc.com/adapter.../charge-cables
Provide more details on your specific batteries, connectors, and desired charge times to get a good recommendation on the ideal charging setup for your needs.
Welcome to RCGroups!
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Dec 24, 2012, 12:22 PM
Joined Jan 2012
Thanks!
The specific batteries are a mix of 110mAh 3.7V lipos and 150mAh 3.7V lipos used in my Blade micro helicopters.
Specifically, these and these.
As for charging time, under 30 minutes would be best but I would not want to damage the batteries.
Old Dec 24, 2012, 12:41 PM
So. Cal.
Ok, here's the harness that you'll need to charge multiple packs in parallel at the same time:
http://www.progressiverc.com/paralle...rge-cable.html
To charge in ~30 minutes, simply add capacities of all packs and then multiply by 2 to get a 2C charge rate.
If you have four 150mAh packs...
4 x 150 x 2 = 1200mA or 1.2 amps charge rate.
Just remember to leave packs discharged after flying and only charge them immediately prior to use. Lipolys do not like to be left fully charged as this damages them and will have you replacing them sooner than you would like.
Mark
Old Dec 24, 2012, 07:07 PM
Joined Jan 2012
Thanks! That is really helpful.
Is there any limit on how fast you can charge the batteries? If I had 2.4 amps could I safely charge them in 15 minutes?
Old Dec 24, 2012, 07:32 PM
So. Cal.
Maximum charge rate is highly dependent on the specific cells. Also, there is diminishing returns when charging at a higher rate due to cell internal resistance and connector losses in small single cell packs.
I personally rarely charge faster than 3C rate as this is very safe for my particular packs and yields a very short charge time.
Charge times can be significantly reduced by storing packs at ~1/2 charge state. This can be accomplished by charging at 'storage' setting after returning from flying. This will bring cells to ~3.8-3.9 volts. The remaining 1/2 can be charged in 15-20 minutes by charging at a safe 2-3C charge rate.
Mark
Old Dec 25, 2012, 06:19 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
A better charger than you referenced would be this:
http://www.progressiverc.com/icharger-106b.html
The higher wattage will allow you to progress to larger batteries. Also Progressive RC will provide better service than Hobby King.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Dec 25, 2012, 11:31 AM
Barbados
Joined Jan 2011
Dalto see that I Charger 106b he just recomended,well go buy it and never look back.Merry Xmas
The Tug is online now Find More Posts by The Tug
Old Dec 25, 2012, 05:57 PM
Joined Jan 2012
So, I would need something to convert the AC power to DC to go along with that?
If so, could you recommend something?
Old Dec 25, 2012, 06:36 PM
USA, GA, Marietta
Joined Aug 2005
Yes you would need a power supply.
mrforsyth offers an excellent choice in either 12V or 24V.
http://www.rcgroups.com/forums/showthread.php?t=1563369
Glen
Question Can you charge 2 6S Lipo in parallel if both 6S are 2S+4S wired in series? os2 Batteries and Chargers 7 Dec 03, 2012 08:55 PM
Cool Only USD8.9 GT POWER Model 2-3 Cell Parallel Charging System RC LiPo Battery Charger szewang2805 Product Announcements 0 Oct 15, 2012 11:11 PM
Discussion Charging 6 individual cells in parallel aussiefly Batteries and Chargers 6 Oct 13, 2012 08:06 PM
Sold Poly Charge 4 / charge 1-4 cells at a time fly2bob Aircraft - Electric - Batteries & Chargers (FS/W) 10 Jun 21, 2012 05:17 PM
Discussion can i charge different mah 1 cell lipos in series? Dr.JJ Batteries and Chargers 5 Feb 25, 2012 07:10 PM
