Old Jul 17, 2006, 12:43 PM
Joined May 2006
edf-65 thrust to weight
hey guys i need a little help here i am trying to find out the usual thrust to weight for an edf-65 fan to be able get decent flight out of. i know that 1 :1 would be great but probable not feasible or???
cdromce is offline Find More Posts by cdromce
Old Jul 17, 2006, 08:09 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
First of all, what motor do you want to use and what airframe do you want to use it in?
1/1 is totaly out of the realm of possiblilties for this fan.
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 18, 2006, 02:32 AM
Joined May 2006
edf-65
Eric B.
eric i am in the process of sizing up dre's f-22 plans to fit the edf-65, as for motor it is the stock motor until i can get some idea of what motors will work in the fan. i appear to be heading for about 7 to 10 oz area in weight. in my blog you can see some of the work i have done to upsize this plan from dre's edf-40 plans. i am a nubie but love to experiment and build things so i hope to get at least a flyer maybe not fast but stays in the sky flyer out of this.
thanks for your help
chuck
Old Jul 18, 2006, 05:07 PM
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Chuck,
We have played around with the GWS64 a bit with both CDrom type motors and with Hyperon 3600Kv inrunners. I think the numbers for the Hyperon was around 17amps for about 15 ounces of thrust on a 3 cell 2100 bat. This was in a airliner type nacelle so you will loose some if it goes into fighter like ducting.
You may want to look at a depron flat plate design. I think I've seen a Panther that was done here about a year ago for the edf64 and it looked pritty good, might try a search.
good luck -- Stacker
stacker is offline Find More Posts by stacker
Old Jul 18, 2006, 07:11 PM
Joined May 2006
edf
Originally Posted by stacker
Chuck,
thanks stacker for the info i will play a bit more with this edf then look into the flat design thanks
Old Jul 18, 2006, 07:50 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
chuck
Hi Chuck,
Go ahead and plunge into the fun, I knew if there was more informaion given there would be someone to help. I fly Wemotecs and the GWS 55 and GWS 40 in different airframes, its all fun.
Eric B.
Old Jul 19, 2006, 01:39 AM
Joined May 2006
Hi Chuck,
Eric B.
thanks eric
Old Jul 19, 2006, 12:01 PM
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Chuck,
Here is a link for a Panther that was done by Esprit440 for edf40 and I believe he also did one for a edf75. This could be scaled for a 64 unit and with a good brushless you might get 1 to 1 using a 20c small bat. pack (1200 3 cell)
http://www.rcgroups.com/forums/showt...4&page=2&pp=15
I think plans are available on the link.
Cheer --- Stacker
Old Jul 19, 2006, 10:24 PM
Joined May 2006
edf
Chuck,
Cheer --- Stacker
thanks stacker i am there dude
Discussion Sub 3" EDF with 2:1 thrust:weight? Bugman Jeff Electric Ducted Fan Jet Talk 4 Feb 20, 2007 09:02 PM
Discussion EDF Thrust to Weight Ratio Gavinb Foamy EDFs 12 Feb 03, 2007 01:03 PM
Thrust to weight ratios (twin series or parallel) Van Power Systems 9 Feb 17, 2002 10:46 AM
EDF-50 airplane weight russ6421 Electric Ducted Fan Jet Talk 2 Nov 28, 2001 09:21 PM
Thrust to weight ratio Frank B Electric Plane Talk 6 Oct 19, 2001 08:08 AM
