Old Oct 19, 2014, 07:11 AM
United Kingdom, England, Bury
Joined Jun 2011
RCTimer Trooper Canopy Problem
Hi guys
I am just completing a build of an RCT Trooper X4.
So far I have test flown without the canopy and all is well.
However I have come to fit the canopy and its not really fitting well.
The hole at the back does not fit over the peg and is about 2mm off centre.
My idea is to cut some material from the front to allow it to slide back further and then be over the hole... but I just wanted to check before I start cutting anything - is there any other solution?
Thanks!
Manc_Heli is offline Find More Posts by Manc_Heli
Old Oct 19, 2014, 07:58 AM
Joined Jun 2011
Hmm... could not cut anything out as it was contacting inside the shell at the front so would have left a hole in the shell.... so in the end I removed the post and used a Velcro tab from the top of the shell down over the back. Should do for testing till I come up with a better solution!
New Product RCTimer Y6 Tri-Trooper 900 Carbon Fiber Frame - Integrated PCB Version Askyvision Multirotor Talk 528 Yesterday 05:49 PM
Build Log RcTimer Trooper Q700/ Sky-Hero Retract landing gear jan michael Scratchbuilt Multirotors 24 Nov 22, 2014 12:33 AM
Sold RCTimer Trooper Q700 Chaser11 Aircraft - Electric - Multirotor (FS/W) 5 Sep 29, 2014 11:32 AM
Help! RCTimer HP1806 2300kv problem hefest Multirotor Power Systems 4 Sep 24, 2014 03:54 PM
Help! Turnigy Trooper 4x4 drive problem xraymiller Car Talk 1 Nov 16, 2013 10:36 PM
