Old Mar 19, 2014, 02:16 PM
GNieuwoudt's Avatar
Joined Apr 2003
Scale glider self launch systems
I have to make a choice for a SLS for my ASW 22, 4m wingspan, which would weigh in around 5kg. I would like to know from the groups experience which systems works best. I have found a few which would do the job:
- the PowerLifter from LF-technik
- the Power Pod launching system from Espritmodel
VS
- a nose job with a motor in the nose like the Xpower brussless motor with longer shaft or the hacker A40 glider conversion kit.
Experiences would be appreciated.
Cheers
Gert
GNieuwoudt is offline Find More Posts by GNieuwoudt
Old Mar 20, 2014, 04:50 PM
New York
Joined Feb 2002
Most simple and cheap: A Nose Job. You can hand launch and if you paint the blades white, they'll disappear visually in an instant. Also is the lightest SLS approach.
The other approaches all have their pluses and minuses. In addition to multiple nose jobs, I've tried a power pod from one of the German suppliers...similar in concept to Esprit's. It does raise and shift the CG. I've had limited flight time with it but not overwhelmed so far.
I've seen the LF system in action at an outdoor trade show in a 4 meter sailplane. Very impressive performance. Costs as much as a tow plane which is typical of most SLS units.
Anyway, something to chew over.
Steve
SteveR is offline Find More Posts by SteveR
Old Mar 24, 2014, 04:50 PM
paulywood's Avatar
United States, CA, Sacramento
Joined Feb 2003
I went with the the nose motor for Cheaper Price, High Performace, & Lighter Package.
Here;
http://www.rcgroups.com/forums/showthread.php?t=2116760
Pauly
paulywood is offline Find More Posts by paulywood
Old Mar 24, 2014, 04:56 PM
New York
Joined Feb 2002
Smart move for all the reasons you noted above!
Steve
Old Mar 24, 2014, 04:59 PM
New York
Joined Feb 2002
One suggestion: position the motor and folding props so the blades look naturally in line with the fuse when folded. No matter what you do, you'll want to add a little elevator compensation with the motor on. Usually it's a bit of down elevator.
Steve
Old Mar 24, 2014, 05:07 PM
paulywood's Avatar
Joined Feb 2003
I went with 3 degress down & 2 degrees right trust.
But thats with over 2000 watts.
Pauly
Old Mar 25, 2014, 11:42 AM
GNieuwoudt's Avatar
Joined Apr 2003
Pauly
The higher performance and lighter package will probably convince me for the nose job. Thanks for the feedback
Cheers
Gert
Old Mar 26, 2014, 05:20 AM
simonslim's Avatar
United Kingdom, England, Northd
Joined Nov 2005
I've built a couple of scale sailplanes with a nose mounted, extended shaft motor. First one was an ASH26 3 meter all glass with an X-Power motor, the second was a 1/4 scale Fox with a 1700w motor with a shaft extension. Both fly extremely well with only a marginal weight gain as the motor replaces the lead needed in the nose to balance.
simonslim is offline Find More Posts by simonslim
Old Mar 26, 2014, 12:37 PM
paulywood's Avatar
Joined Feb 2003
Very Nice....
Old Mar 26, 2014, 02:16 PM
union1's Avatar
United Kingdom, England, Sudbury
Great stuff!
Are the shaft extensions available commercially?
union1 is online now Find More Posts by union1
Old Mar 30, 2014, 11:24 PM
paulywood's Avatar
Joined Feb 2003
Originally Posted by union1 View Post
Great stuff!
Scroll down a bit;
http://www.espritmodel.com/new-2014-season.aspx
Pauly
Gallery SLS (Self Launching System) 4.5m Ventus 2CX & Dolly Trolley Wagon paulywood Scale Sailplanes 21 Apr 02, 2014 10:41 AM
Gallery SLS (Self Launching System) 4.5m Ventus 2CX & Dolly Trolley Wagon paulywood Electric Sailplanes 11 Mar 31, 2014 11:49 PM
Question Self launch system for ~10-12lb glider KNS Electric Sailplanes 0 Mar 12, 2014 03:40 AM
Discussion Most proven self launching systems? edfmaniac Scale Sailplanes 27 Jan 10, 2014 04:17 AM
Scale Glider Self Launch System lighthorse Scale Sailplanes 7 Oct 20, 2005 08:45 PM
