Old Mar 21, 2013, 08:26 AM
Australia, NSW, Wollstonecraft
Joined Sep 2012
Propeller and Spinner alignment problem
hey everyone
can someone please explain to me how to align the spinner with the prop properly. My problem is when I tighten the nut, i have to hold the prop, causing it to move the other way(and therefore is not aligned with the spinner top).
The first photo shows the problem and the second shows what happened to my last spinner.
Any input is appreciated.
Ironaut is offline Find More Posts by Ironaut
Old Mar 21, 2013, 09:04 AM
Lumpy05's Avatar
United States, IN, Bloomington
Joined Jan 2012
I have also had problems with plastic spinners on glow engine planes. Two thoughts:
1. hold the spinner back plate perhaps with a screwdriver through a hole while tightening the prop which should push the prop against the alignment tabs.
2. Give up on plastic spinner and go with Tru-turn aluminum spinner. (My prefererred solution, with side benefit of not getting chewed up by electric starter)
Lumpy05 is offline Find More Posts by Lumpy05
Old Mar 21, 2013, 12:14 PM
United States, OR, Canby
Joined Aug 2011
Does the nut turn freely on the shaft until it comes in contact with the washer? I have not had that problem, once the nut starts to clamp down everything seems tight. But if the nut is a little tight on the threads I can see how it would be a problem.
While an aluminum spinner is nice it is not the solution, sure it won't get buggered up if the prop touches it but the prop should never be in contact with the spinner.
600Bob is offline Find More Posts by 600Bob
Old Mar 21, 2013, 12:25 PM
Lumpy05's Avatar
Joined Jan 2012
It is for me as there are no alignment tabs on the aluminum backplate, basicly eliminating the need to tighten the prop in a specific nonforgiving position. You do have to be careful to put the spinner on such that it NEVER touches the prop which is easy to do because it doesnt have to line up with the screw holes like a plastic spinner.
Old Mar 21, 2013, 12:31 PM
Joined Aug 2011
Yes that is true. I have both alum. and plastic props but have not had the problem the OP has had with plastic ones.
Old Mar 21, 2013, 02:12 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
the problem with plastic spinners, is once you tighten them down, they squish a pattern into the backing plate! and they will allways try and go back to that same position!
the only way to stop that, is too put the prop on in the right spot the first time! I usta bias the prop in the other direction, and then when tightening the prop nut, the prop would center itself!
never go for the last twist, until you are sure that the prop is centerd in the cone!
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: great day!
Old Mar 21, 2013, 05:53 PM
Joined Sep 2012
Good idea!
Old Mar 21, 2013, 09:19 PM
Transplant in 1996
United States, NE, Scribner
Joined Aug 2011
I am sorry to say, BUT plastic prop spinners are USELESS. I am sorry, but they do not work.
After I got my first Aluminum spinner, I threw ALL my plastics into the burn barrel.
Transplant92 is offline Find More Posts by Transplant92
Old Mar 22, 2013, 09:01 AM
WCB
NC
Joined Aug 2005
An alternative to plastic spinners is a Dubro aluminum spinner nut. They are inexpensive, easy to install and look ok. I use them a lot on small glo engines.
WCB is offline Find More Posts by WCB
Old Mar 22, 2013, 01:42 PM
Joined Aug 2011
Seems a little harsh. I have three, one on a small gas engine the other two on glow and have never had problems with them, they do get buggered up from starters though. I do put alum. On my new bigger planes though, more $ but much nicer.
Old Mar 22, 2013, 03:01 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
DU-BRO been making decent nose cones for ever! ya they don't last forever, but hey there not alot of money! better then natta!
ya they can be a lil finicky, I have used them since I started, and will have one on my latest plane!
http://static.rcgroups.net/forums/at...4-100_0195.jpg
the one on my PITTS is a 3" and I have a 4" on my P-51!
Old Mar 22, 2013, 08:37 PM
Transplant in 1996
Joined Aug 2011
whiskykid That is a BEUTIFULL airplane, I'd trade you my hart for it!!!!
Old Mar 22, 2013, 09:55 PM
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
I completely agree !!! Plastic spinners suck. For your Plane. You don't need a big spinner. I use a spinner nut. But mine is pretty. Mine is blue and has a pointed nose. You spin it on and use a small screw driver to tighten. Some do look dumb. They look like a blunt nose with a molded nut lookin deal.
Dale 813 is offline Find More Posts by Dale 813
Old Mar 22, 2013, 09:58 PM
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
,ooo
Old Mar 23, 2013, 05:50 AM
hawl131's Avatar
United States, CO, Colorado Springs
Joined Mar 2013
I chunked all of my plastic spinners, they were starting to be a big problem this fall and I won't use them anymore. They would melt when I used the starter, slip and spin off or the starter would slip and wouldn't turn the spinner. They suck donkey *****......
hawl131 is offline Find More Posts by hawl131
Sold 42mm spinner and 12x8.5F folding propeller $12 shipped moodified13 Aircraft - Sailplanes (FS/W) 1 Jan 13, 2013 06:21 PM
For Sale Propellers, Folding props, spinners PetruSoroaga Aircraft - Electric - Power Systems (FS/W) 4 Aug 07, 2007 12:42 AM
Discussion How can I mount a propeller and spinner on an outrunner? Dave K Power Systems 3 Dec 06, 2006 08:57 PM
?Trainer Propeller Hub Nut/Spinner Question? basebalplayr33 Fuel Plane Talk 5 Jul 20, 2005 08:18 PM
MIG 280GPMIG 280 1.4:1 Gear,Propeller, & Spinner $11.00 shipped 1987tc Aircraft - Electric - Airplanes (FS/W) 2 Nov 06, 2004 05:28 PM
