Old Sep 10, 2012, 09:22 PM
Joined Jul 2012
Help!
Castle Ice 100 AXI 2820/10 noise
any ideas guys?
just started doing this and i got a 4 tone warning on my last flight
Castle Ice AXI 2820-10 Noise (0 min 33 sec)
thanks in advance!!
rc_fpv is offline Find More Posts by rc_fpv
Reply With Quote  (Disabled)
Old Sep 11, 2012, 09:03 AM
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
4 tones is a motor anomaly. AXI motors are kinda difficult to run with any controller other than a Jetti but with the right settings the Castle controllers usually do very well.
I run quiet a few AXI motors & 8khz PWM & Low Timing range has always been the ticket.
I don't know what your settings are but try that & see what you get plus things change a little with a load so stick a prop on there as well to make sure the setting are going to be sufficient.
Steve
RS Rogers is offline Find More Posts by RS Rogers
Old Sep 11, 2012, 10:17 AM
A man with too many toys
United States
Joined Feb 2001
Low Timing is the way to go.
PWM of 8 or 12 should be about the same.
RC Man is offline Find More Posts by RC Man
Old Sep 11, 2012, 10:29 AM
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
I found on some versions of firmware anything above 8 would cause an out of phase (squealing noise) - but some versions not. 8's always been safe.
Timing on Castle controllers can be a little misleading if the info box for the setting inst looked at. The setting refers to a dynamic range - not actual degrees, & since AXI motors are high timed motors we want to use a very low dynamic expansion range thus the Low setting on timing.
Just a little fyi in case you wonder why we recommend low timing setting when AXI recommends 22 - 24 deg. of timing if I remember correct.
Steve
Old Sep 11, 2012, 11:34 AM
Joined Jul 2012
Awesome. I took the prop off to diagnose and keep my fingers I have a squeal with it on at about the same position as the wah wah
Old Sep 11, 2012, 11:36 AM
Joined Jul 2012
Also what is the f/w version that I should be on? I think I was at 3.27 here. I stopped with 4.0 cause I had the issue stated
Old Sep 11, 2012, 12:52 PM
RS Rogers's Avatar
Clyde N.C.
Joined Oct 2003
3.27 should work fine. I haven't tried any of the newer with an AXI. It should be the same with newer versions as most changes on those only apply to multi rotor & helis
Steve
Old Sep 11, 2012, 04:14 PM
Joined Jul 2012
ok gave that a shot the 3.27 (i was on 4.01), 8pwm, and 0 timing, it did move the noise to the lower part of the throttle, so at least i wont be flying in it. more testing to come
For Sale NIB AXI 2820/10 Gold sharonx Aircraft - Electric - Power Systems (FS/W) 0 Aug 28, 2012 04:22 PM
Sold AXI Gold 2820/10 BL Motor w/GP 45a ESC Combo HugoCraft Aircraft - Electric - Power Systems (FS/W) 2 Jul 17, 2012 09:41 AM
For Sale Axi 2820/10 gold line *NIB* sharonx Aircraft - Electric - Power Systems (FS/W) 0 Jun 23, 2012 06:20 AM
For Sale Axi 2820/10 gold line *NIB* sharonx Aircraft - Electric - Power Systems (FS/W) 0 Jun 18, 2012 05:07 AM
For Sale Axi 2820/10 gold line *NIB* sharonx Aircraft - Electric - Power Systems (FS/W) 0 Jun 12, 2012 10:53 AM
