Old Dec 27, 2010, 09:50 PM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS new servos S03T-II and GWS S03T-II D
S03T-II 2BBMG Test datas:
0.174sec/16.5Kg 4.8DCV
0.145/18.0Kg 6.0DCV
0.122/20.0Kg 7.4DCV for Standard
0.147sec/15.0Kg 4.8DCV
0.122/18.0Kg 6.0DCV
0.096/19.5Kg 7.4DCV for F= Fast version
0.113sec/13.0Kg 4.8DCV
0.093/16.0Kg 6.0DCV
0.075/18.0Kg 7.4DCV XF= extra fast!
The size similar to S03T, final specs of the case will be posted soon.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Dec 27, 2010, 09:56 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
S03t-ii d 2bbmg
S03T-II Digital 2BBMG Test datas:
0.173sec/17.0Kg 4.8DCV
0.143/19.0Kg 6.0DCV
0.120/21.0Kg 7.4DCV
0.110/23.0Kg 8.4V for Standard
0.145sec/15.0Kg 4.8DCV
0.120/18.0Kg 6.0DCV
0.096/20.0Kg 7.4DCV
0.088/21.0KG for F= Fast version
0.111sec/14.0Kg 4.8DCV
0.092/17.0Kg 6.0DCV
0.074/19.0Kg 7.4DCV
0.068/20.0Kg XF= extra fast!
Old Jan 13, 2011, 02:07 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Supprised that such a nice performance of a standard size servo did not catch your eyes?
The performance similar to most of those $120~$200 servos, but GWS will them sold at
S03T-II Digital 2BBMG at $35.00
S03T-II 2BBMG at $30.00
Hope this will be a miracle for 2011.
Old Jan 18, 2011, 11:33 PM
Joined Jan 2011
Dear GWS4CEO,
I would like to build an hexapod robot using 18 servos.
My choice is to use 18 servo model: GWS S03T STD
I am just wondering if I should get the GWS S03T 2BB MG instead or if I could upgrade later, adding metal gear and ball bearing to my GWS S03T STD.
What do you think?
Thanks a lot for your help.
virtualmix is offline Find More Posts by virtualmix
Old Jan 19, 2011, 03:17 AM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
How heavy is that robot?
S03T in POM engineering plastic can hold up to 8Kg-cm, load more than 10Kg-cm will possible to damage the gears!
For heavy load users, metal gear version will be a better choice!
However, a standard POM gear set can be up grade with metal gears easily!
Old Jan 19, 2011, 06:06 AM
Joined Jan 2011
Thank you GWS4CEO for your answer
I'm still designing the robot therefore I'm not sure yet how heavy it is going to be. I'm trying to keep it as light weight as possible and I will perform a weight and force calculation before ordering the servos.
I have 2 more questions:
- Do you know if GWS S03T STD have ball bearings?
- Where can I purchase a metal gears set to upgrade the GWS S03T STD ?
Thanks for your time
Old Jan 21, 2011, 08:20 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
GWS S03T 2BB have 2 ball bearings.
You may replace metal gears. But better to buy GWS S03T MG2BB
Discussion GWS S03N-II HP and GWS S03N-II D HP2BB GWS4CEO GWS (Grand Wing Servo) 17 Jan 21, 2014 01:31 AM
Discussion GWS S03N-II HP and GWS S03N-II D HP2BB ( D= Digital ) GWS4CEO Australia 11 Jul 09, 2011 11:43 PM
Discussion GWS S03N-II HP and S03N-II D HP2BB 標準型舵機新標準! GWS4CEO China 4 Dec 01, 2010 03:19 AM
Discussion GWS new servos S03N-II HP and GWS S03N-II D HP weight 33g only! GWS4CEO Radios 0 Nov 12, 2010 04:27 AM
Discussion GWS S03N-II HP and GWS S03N-II D HP2BB GWS4CEO Japan 0 Nov 12, 2010 04:19 AM
