Espritmodel.com Heli Air
Old Apr 26, 2013, 11:32 AM
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Looking for a small, quiet edf
Hey all, I'm new to the edf stuff.
My next project I want to do a small edf jet with a wingspan not greater than around 24 inches. I made a scratch-built pusher prop cutlass and was really impressed with the way this airframe tracked, like it's on rails, until I had a Rx glitch on my FM system and an evil tree ate it with a happy woomp sound. I want to make the next one edf.
I am assuming I would want an edf around 50mm for a lightweight plane this size?
Problem is my field is "noise sensitive". I heard the Change sun fans are real quiet but I can't find any smaller ones.
Thanks for any suggestions.
rotagen is offline Find More Posts by rotagen
Old Apr 26, 2013, 12:02 PM
JGuilty13's Avatar
United States, MI, Royal Oak
Joined Nov 2005
Grab a 50mm T45 kit (Jpower or Skyangels) and put the new Lander 10-blade 50mm unit in. Quit a bit quieter than stock.....sounds sweet though. Plus the T45 is just a great airframe. Just my .02.
JGuilty13 is offline Find More Posts by JGuilty13
Old Apr 26, 2013, 12:11 PM
rotagen's Avatar
Joined Jan 2005
Thanks for the suggestion, I do like the looks of those jpower airframes.
Found a vid with the Lander and it does indeed sound reasonably quiet, problem is even after translating he doesn't seem to mention the motor he used. I'm thinking the motor contributes to the noise of course.
http://translate.google.com/translat...%3DCFO0FI26Zps
Old Apr 26, 2013, 12:25 PM
JGuilty13's Avatar
Joined Nov 2005
the fan blades (and if they are properly balanced) contributes much much more to the noise than the actual motor ever will.
Old Apr 26, 2013, 12:57 PM
rotagen's Avatar
Joined Jan 2005
Yeah I have heard that about the balancing.
Well about a year ago I almost bought the Change Sun 10-blade 70mm unit after seeing some youtube vids and being impressed with the quiet natural sound, shoulda woulda coulda.
Now I am bummed because apparently it is no longer produced and their 12-blade sounds louder to my ears, can anyone confirm this?
Call me weird, but the high-pitched squeal of most edfs is really annoying to my ear. Thanks for any ideas. Hmm, I was hoping to try out an edf system but I may just make another pusher.
Old Apr 26, 2013, 01:47 PM
Manu Simon's Avatar
Belgium
Joined Aug 2008
You can still get the CS 70mm 10 blades here for $15 +$5
Stick that one in a lander F9F Panther and you'll get a very quiet EDF.
Mine is set up with CS10 and Turnigy L2855 2300kv on 5S and is the quietest of all my EDFs
Manu Simon is offline Find More Posts by Manu Simon
Old Apr 26, 2013, 02:48 PM
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
7blade 50mm EDF sounds just about as little as you ever will get one to sound.
Henke's 50mm 7blade T-33 (3 min 21 sec)
henke is offline Find More Posts by henke
Old Apr 26, 2013, 04:40 PM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
the 12 CS fan will be just as quiet as the 10 blade if balanced properly. It just draws a little more current (about 7%w with the same motor).
Cheers
4stripes is offline Find More Posts by 4stripes
Old Apr 26, 2013, 09:39 PM
that's gonna leave a scar
KCinNC's Avatar
Marina Village, NC
Joined Aug 2007
i just put this setup in my 50mm T-45
http://donsrc.com/cart/index.php?_a=...&product_id=97
5400kv motor, i use a 1300mah 40C 3s batt...faster than stock motor.....very low noise !
got it balanced for $10 ...makes a difference
KCinNC is offline Find More Posts by KCinNC
Old Apr 27, 2013, 07:08 PM
FireHawx
Joined Oct 2011
RC Castle just put out an 11 blade CS 50mm edf TODAY......for $20 w/a motor!
FireHawx is offline Find More Posts by FireHawx
Old Apr 29, 2013, 01:13 AM
Joined Nov 2011
is it dynamically prebalanced ???
but it looks ok on paper though
- Overall Weight : 66g ( Whole Unit )
- Working Voltage: 3S 11.1v
- Static Thrust : Around 410g At 11.1v (25A)\
flylow2011 is online now Find More Posts by flylow2011
Old Apr 30, 2013, 03:06 AM
rotagen's Avatar
Joined Jan 2005
Wow great responses. Thanks for your help all, that was a nice sounding edf henke, but I am feeling cheap so I went with the RC castle combo. Thanks also for the heads-up Manu, picked up a couple CS 10-blades.
Old Apr 30, 2013, 03:39 PM
henke's Avatar
Joined Jan 2001
Multiblade well balanced seem to be the way to go :-) I choose the Hacker as I got it laying around from a Hornet 2 Helicopter. I bet there are cheaper alternatives now days.
Discussion looking for a portable and quiet warbird soundmaster Electric Warbirds 11 Apr 27, 2013 06:54 PM
Discussion Looking for a small spray gun and airbrush. Gooroo The Builders Workshop 6 Apr 05, 2013 05:46 PM
Discussion Looking for a small 2 axis gimbal for my TBS Discovery, is there anything out there ? jasper7821 Aerial Photography 11 Apr 05, 2013 03:55 AM
Discussion looking for small charger/discharger wolfv FMA Direct 3 Mar 29, 2013 11:15 AM
Discussion Looking for a small camera system for remote viewing deathrow Radios 5 Jan 31, 2013 05:56 AM
