Old May 21, 2015, 01:54 AM
Mal Bond is offline
Find More Posts by Mal Bond
Mal Bond's Avatar
United Kingdom, Sidcup
Joined Jun 2012
Finished Wing Weight and other parts
Originally Posted by Windependence View Post
I have been making some more progress on the Manta. There are a ton of little fiddly things to do on the wing, servo wiring, hard points on the wing, fiberglass where the throwing peg will go, on and on it seemed to go. But I am finally getting some color added to the wing. This is where I left things this evening, the sheeted area will be red. Aileron will most likely be yellow but my mind is not made op on that one yet. The bottom will get a stripe or two for good measure.
So far the wing is at 135 grams. That includes servos, control horns, basically everything except the remaining covering and a 4 pin Deans connector. I'm honestly not sure if that is good or not. I guess I'll find out soon enough. Tail pieces are up next, it will be interesting to see how they come out.
Wayne
Hi Wayne :-)
What you have posted is looking good.
I may be told otherwise but I believe that if your fully fitted out and covered wing is under 150g you are doing well.
Just don't have a blow out now and find you go over that.
Tail parts will be a challenge. If you can get those below 15g the pair, covered and finished that will be good. Under 12g and you will be doing very well.
Here is your target weight and aerodynamically speaking:-
http://www.hyperflight.co.uk/product...N&name=dlg-fin
Weight: 5.9 g
and
http://www.hyperflight.co.uk/product...=dlg-tailplane
Weight 6.1g
If you get the pod and boom with 2 servos in @ under 75g you are seriously on a winner. That will be hard but remember it is the back end that is the place where the weight must be low.
This is building up (excuse the punn), to be a great result there for you.
All the best.
Mal :-)
Mal Bond is offline Find More Posts by Mal Bond
Old May 21, 2015, 09:22 AM
Windependence is offline
Find More Posts by Windependence
Quando Omni Flunkus Moritati
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Hi Mal,
I agree, the tail set will be the most challenging component to build within modern acceptable weight limits. I will see what I can do with tails included in my short kit and if I don't like the weight I will go off on my own and build something. The fuse weight won't be an issue on this one as I am using a Topsky 3 pod and a boom from HyperFlight. I might throw the pod, boom, and all the electronics on the scale tonight to get a feel for where that is going to weigh in at.
Wayne
Windependence is offline Find More Posts by Windependence
Old May 22, 2015, 04:30 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Built some new tails and now I've hit 14g for the pair
Will post pictures at some point today ( took a leaf out of Traian 'a tail building book)
And started covering the wing ...
Keenan smith is offline Find More Posts by Keenan smith
Old May 27, 2015, 11:51 PM
USA, MN, Rochester
Joined Mar 2008
Made a little more progress on the Manta. Now it is on to the tail and the horizontal mount. Should be interesting to see how it turns out.
Wayne
Old May 28, 2015, 12:09 AM
Mal Bond is offline
Mal Bond's Avatar
Joined Jun 2012
Looking Good
Wayne
Hi Wayne,
That looks so good so far :-)
It deserves to fly well when it looks like that.
What pod and boom are you using ?
Good luck with building the Tail Feathers.
Keenan got into difficulty trying to build his Tail Feathers.
He had difficulty getting the finished weight down.
He has proposed going with the way it is being done on the Evolution W:-
http://www.rcgroups.com/forums/showp...&postcount=293
I do hope this is helpful.
All the Best.
Mal :-)
Old May 28, 2015, 03:53 AM
Joined Dec 2010
Originally Posted by Mal Bond View Post
Hi Wayne,
All the Best.
Mal :-)
Hey Mal,
I did manage getting the tail weight down to 14.8g for the pair covered
And they still seem stiff enough for my liking. Also I have still yet to cut weight saving holes in my Flapperons, the new of can out nice and light too
AUW including boom is 248g (minus rx and lipo)
Here is some pics of the new tails
The wing has also been covered now
Keenan
Old May 28, 2015, 11:11 AM
USA, MN, Rochester
Joined Mar 2008
Hi Wayne,
All the Best.
Mal :-)
I am using a Topsky 3 pod and the boom is from Hyperflight. Hopefully I won't destroy the pod during my DLG learning curve as I am hoping to use it for a while. They are hard to find.
I have been watching the thread on the Evo W and I am on the waiting list for a wing kit on his second run. I am very impressed with his design and I am eager to see it first hand. I will try to get some weights of the tail pieces that were included in my Manta short kit. It would be interesting to know where I am starting at.
Wayne
Old Jun 04, 2015, 09:17 AM
Mal Bond is offline
Mal Bond's Avatar
Joined Jun 2012
No Rudder and Tissue covers Tail Feathers.
Originally Posted by Keenan smith View Post
Hey Mal,
Keenan
Hi Keenan,
From your photos it looks like you are going for No Rudder, All Flying Horizontal Stab and Tissue covered tail feathers.
That is an interesting set of choices.
I assume you will be able to get the wrinkles out of the tissue ?
It will be good to see how you do with your All Flying Horizontal Stab Mount and hear if there is any weight penalty there.
Are you buying a V-Mount for your horizontal Stab or are you making that?
Flying with no rudder has been done on DLGs to save weight in the pod but I don't think that will be an issue for you. It will certainly have you working harder with the Ailerons/Flaps and elevator to get nice thermal turns.
Your work is looking good and it will be good to see how it comes along.
Fortunately the good weather seems to be here more now. So you should get a good bit of flying time to set up and trim your bird.
All the best.
Mal :-)
Old Jun 15, 2015, 03:28 PM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
What is the most recent e-mail addy for DPCModels?
prodjx is offline Find More Posts by prodjx
Old Jun 15, 2015, 03:42 PM
Mal Bond is offline
Mal Bond's Avatar
Joined Jun 2012
This is what I found :-
dpcmodels@aol.com
http://dpcmodels.homestead.com/howtoorder.html
Hope it helps.
Mal :-)
Old Jun 15, 2015, 08:36 PM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
I went there too but it doesn't have a list of the other model's that he laser cut's for.
Old Jun 15, 2015, 08:52 PM
USA, MN, Rochester
Joined Mar 2008
He doesn't list every kit on his website. It is best to contact him and see if he has any or will cut you a kit.
Wayne
Discussion Project Rays - Hyperbolic Manta Geode Hand Launch 28 Jun 12, 2008 09:50 AM
