Old Jul 12, 2015, 09:25 AM
rmsingh is offline
Find More Posts by rmsingh
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
DLE-20RA question
I'm not sure whether I'm over thinking this or not.
I have a DLE-20RA which had 2 flights on it. When I first started it, I did not make any adjustments (straight out of the box), and it started right away. There was a little burble around the mid range, but that was it. 1.5 turns out for both low and high speed needles.
It sat around for about 6 months, then moved it to another plane. Now it requires 3 turns out on the low end needle to start and run. The high is still at 1.5 turns. I flew it last week and the performance was quite rough and dead sticked (ran out of fuel).
I was told at the field that the fuel was probably bad. So today I picked up fresh fuel added oil (30:1) added stabiliser and ran the engine.
Started up OK, runs well, transitions well, but low speed needle is still at 3 turns out.
Should I be concerned? Even the idle set screw cannot reach it (when idling) when screwed all the way in.
rmsingh is offline Find More Posts by rmsingh
Old Jul 13, 2015, 05:35 PM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
It sounds like you're still in your first gallon. If so, you're not broke in yet. The idle won't settle down until you get close to the end of the first gallon. The low speed needle is what concerns me, 3 turns out is generally too many. You might have some junk in the filter screen, the one inside the carb. You'll have to take a side cover off to get to it. The high and the low needles overlap by quite a bit. I'd reset the low and try again.
I've got three of the 20ra. One with lots of time and two new ones about to be fired up. It's one of the few engines I have that was near perfect out of the box.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Jul 13, 2015, 08:06 PM
rmsingh is offline
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
Edwin
Thanks Edwin, I'll that a try.
Old Jul 15, 2015, 04:37 AM
larryoakley is offline
Find More Posts by larryoakley
Joined Mar 2012
Edwin
+1 Take out the carburetor and make sure everything is clean, specially the internal mesh/filter, definitely 3 turns is too much
larryoakley is offline Find More Posts by larryoakley
Old Jul 15, 2015, 02:40 PM
kerwin50 is online now
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Never mix oils it can cause gelling. Check your mesh screen. Even 1 1/2 turns on the HS is wrong. Those are starting points. Make sure your lines are all tight. A loose fuel line can cause a lean mixture
kerwin50 is online now Find More Posts by kerwin50
Old Jul 15, 2015, 07:47 PM
rmsingh is offline
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
I'll pull it apart this weekend. No oil was mixed, only used Evolution 2 Stroke. I was told that if the mesh filter was obstructed, it would not run at all or run only at low speeds. All fuel lines checked. All connections clamped.
Old Jul 18, 2015, 02:06 PM
rmsingh is offline
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
I removed the carb.
The filter is clear, no obstructions.
Checked the reed valves. One of them did not seem to seat well. There was a tiny speck of dust, removed dust. Reed valve now seats completely.
Removed LS needle. Nothing much to clean.
Opened pump, everything seems OK. Nothing to clean there.
Re-assembled and started. Requires 1.5 - 2 turns on LS and 1.5 turns on HS to start and run. but will not idle consistently. Will idle high and then drop and cut out. Runs perfectly above half throttle. Transition is OK but not consistent.
Seems the HS is OK but problems with LS.
Any ideas?
Old Jul 18, 2015, 02:54 PM
ahicks is online now
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
If it's quitting on idle, it's generally too lean. That could be an LS needle adjustment, dirt in the low speed circuit, or a vacuum leak.
You can remove that low speed idle stop screw and throw it away. You'll be setting your idle speed with the throttle servo. That screw serves no purpose in any RC application.
Don't hear about it happening much, but if the carb is open that far on idle, and you're talking about the LS being open 3 turns, you could be WAY rich. Starting over again at 1.5 turns on the LS might be a good plan?
ahicks is online now Find More Posts by ahicks
Old Jul 18, 2015, 06:09 PM
Joined Sep 2003
What he said, but keep in mind if it's not broken in yet, the idle will be unstable for a bit. It took about a gallon for mine to settle down. Each time you adjust the low speed go back and readjust the high speed. The needles over lap by quit a bit, except at idle and full throttle.
Edwin
Old Jul 18, 2015, 07:23 PM
rmsingh is offline
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
The idle is not just unstable. It idles very high and drops and dies. This engine ran smoothly right out of the box. I'm stumped and is ready to buy another carb. I really like this engine but can't figure out this problem.
Old Jul 18, 2015, 07:52 PM
Joined Aug 2008
Can you expand a little on "idles very high and drops down and dies" please?
Is this occurring after it's been run wide open for a while?
Old Jul 19, 2015, 07:06 AM
rmsingh is offline
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
Yes it does. I run for about 10 sec on full, cut to about half and rev up. The transition above half is smooth and response is crisp. If I drop the throttle below half it will sometimes stay at revs around 3.5 - 4k for about 4- secs before dropping to under 2k where it will then cut off.
I tried opening the LS when at idle, but it does not improve until I rev up again, before adjusting the LS. Opening the LS beyond 3 turns does not improve it. 2.5 - 3 turns gets it idling sort of.
Old Jul 19, 2015, 08:41 AM
Joined Aug 2008
OK. You sound like you might be experiencing what is commonly known as "high idle hang". All 2 strokes are capable of it.
The short story is that it's caused by a lean LS setting. To expand a little, the combustion chamber is hot from the high speed run, and taking it's darn sweet time to cool down when the throttle is closed (4 sec. in this case) - due to the lean LS setting. The correct LS setting allows enough fuel entering the combustion chamber to cool it quickly. A lean condition is basically allowing it to "diesel" until it cools.
When taking all your comments at once, especially the one saying you've been 3 turns out on the LS, this makes no sense at all.
Are you adjusting the high speed needle first (to peak), then adjusting the LS for best transition (or maybe just slightly rich of that) afterward?
Old Jul 19, 2015, 08:53 AM
Joined Sep 2003
That was the best explanation of the high idle hang I've heard yet.
Edwin
Old Jul 19, 2015, 09:07 AM
rmsingh is offline
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
Exactly. I did notice a slight drop at full throttle maybe the HS is lean. I will open the HS from 1.5 to 2 turns then adjust the LS again.
Thanks for your help. I'll report back.
Sold Dle-20ra hi2nr Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 27, 2015 08:47 AM
Sold DLE-20RA Engine RCMC Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 22, 2015 07:45 AM
Question More DLE 20RA Questions SpadCat2000 Engines 9 Mar 06, 2015 08:07 AM
Discussion DLE 20RA Questions SpadCat2000 Engines 12 Mar 01, 2015 12:10 AM
New Product Dle 20ra DMHIGHFLYER Engines 14 Oct 28, 2013 12:11 AM
