Old Apr 13, 2015, 10:34 PM
madmike8 is offline
Find More Posts by madmike8
madmike8's Avatar
USA, TN, Fayetteville
Joined Dec 2004
HiPro HP-W500-FF3 & HP-R650-FF3 Server PS Wiring.
I didn't see this listed anywhere, so I thought I'd post it up in hopes that it will help someone.
Hipro HP-W500FF3 500W Server Power Supply
12v @ 41 Amps
5v @ 2 Amps
Hipro HP-R650-FF3
12v @ 54 Amps
5v @ 3.5 Amps
This has a slot style connection. With the Hipro label up the top of the blade left to right under the fan.
1 2 3 4 5 6 Gnd. 12V
3 Ps_On_Ctl
4 Ps_Kill
6 5vsb
Bottom side of the blade two larger pads are Gnd and 12v again
To turn on the power supply tie both Ps_On_Ctl and Ps_Kill to Gnd.
That ought to do her...
madmike8 is offline Find More Posts by madmike8
Old Apr 14, 2015, 01:46 PM
madmike8 is offline
madmike8's Avatar
Joined Dec 2004
More Pictures. And better details.
Remove these 5 screws
And open the case to make it easier to solder wires.
Description:
Description:
Description:
Pull back the case, and connect wires on the correct pads.
Description:
Description:
Description:
Close it back up and put the screws back in.
Turn on the power supply by connecting PS_On and PS_Kill to Gnd.
Hope that helps.
Old Apr 15, 2015, 08:13 PM
madmike8 is offline
madmike8's Avatar
Joined Dec 2004
I made a cover/ mount for it. The files can be found here.http://www.thingiverse.com/thing:773924
Description:
Old Apr 20, 2015, 12:32 PM
madmike8 is offline
madmike8's Avatar
Joined Dec 2004
I printed out the other end of my power supply holder today.
Description:
Description:
Fits good. I even added in the slots for the hot swap locking mechanism.
Btw, I'm going to paint these flat black before they are installed permanently. I will add some deans connectors housings and a switch to complete the setup.
Old Apr 21, 2015, 12:05 AM
madmike8 is offline
madmike8's Avatar
Joined Dec 2004
I got the parts painted black, and got the Deans Connector mount installed. I still have to get an on-off switch mounted.
Description:
Description:
Description:
Description:
Old Apr 22, 2015, 09:45 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Suggest you put a link to this thread in the sticky reference thread here.
http://www.rcgroups.com/forums/showthread.php?t=1292514
John
jj604 is online now Find More Posts by jj604
Old Jul 29, 2015, 02:19 PM
snapper1234 is offline
Find More Posts by snapper1234
snapper1234's Avatar
Germany, HB, Bremen
Joined Dec 2008
Hi everybody
My Hipro HP-R650-FF3 is currently dead
I found this (Russian Forum)
http://abzala.com/m/articles/view/%D...pro-HP-R650FF3
and have the electrolytic capacitors exchanged unfortunately but without success
C209 and C210 were definitely burst
anyone an idea how I can revive it here or even has a wiring diagram for the power supply ?
best regards
snapper1234 is offline Find More Posts by snapper1234
Discussion Easiest Server PS to Decouple dc ground bob93447 Batteries and Chargers 4 Feb 20, 2014 08:51 AM
Sold Cellpro PowerLab 6 Charger W/ 24v 1000w Power Supply (Dual HP Server PS) Wangta Aircraft - Electric - Batteries & Chargers (FS/W) 16 Jan 02, 2014 04:22 PM
Question Question on HP 47A server PS Lardog Batteries and Chargers 2 Mar 30, 2011 11:03 PM
Discussion Server PS to Bench PS jetblack DIY Electronics 3 Oct 16, 2009 12:40 AM
