Old Feb 21, 2015, 09:34 PM
avogodro is offline
Find More Posts by avogodro
Joined Mar 2007
hkpilot micro apm 2.7 and ppm
Hello
I hope this isnt a stupid question. I tried to search and I was unable to find clear instructions on how to connect a ppm receiver like the frsky d4r-ii. This is all i could find....
http://diydrones.com/m/blogpost?id=7...Post%3A1882504
at the bottom it says to jumper a resistor to ground and then jumper to enter dfu mode. Can someone explain this process to me? HK doesnt have any good documentation as usual.
A-
avogodro is offline Find More Posts by avogodro
Old Feb 21, 2015, 10:37 PM
Toastdude82 is offline
Find More Posts by Toastdude82
United States, VA, Newport News
Joined Dec 2014
For a standard ppm connection you should just have to jumper inputs 2 and 3 together and connect the ppm to channel 1. If it is an s bus output then u have to replace some firmware.
Toastdude82 is offline Find More Posts by Toastdude82
Old Feb 22, 2015, 01:03 AM
avogodro is offline
Joined Mar 2007
So just cut the leads of 2 & 3 and splice them together? And connect receiver to ch 1?
Old Feb 22, 2015, 07:06 AM
Akokaram is online now
Find More Posts by Akokaram
Joined Apr 2014
Originally Posted by avogodro View Post
Hello
A-
Thanks for that link. I've been looking for that info.
Akokaram is online now Find More Posts by Akokaram
Old Feb 22, 2015, 07:16 PM
avogodro is offline
Joined Mar 2007
Great. Your welcome. So do I need to put a dab of solder on the contact the first arrow is pointing to? I wouldn't need to put this in dfu mode right? Sorry I am very new to apm.
Old Feb 22, 2015, 07:23 PM
Joined Dec 2014
No u should just have to momentarily short them to enter dfu mode.
Old Feb 22, 2015, 07:38 PM
avogodro is offline
Joined Mar 2007
Can you explain the process for me then. I am completely confused. Sorry.
Old Feb 22, 2015, 09:25 PM
Joined Dec 2014
So I don't have the HK version but mine came with a standard ppm encoder already loaded on it. For the standard ppm encoder to work you just have to shor channels 2 and 3 together and use channel 1 as the ppm input. If u want to use s bus then u will have to replace the firmware on the 32u2 chip which requires entering dfu mode. The first link below shows how to use a standard ppm reciever the second shows how to use sbus. Note in the second that it says to solder at one point. That entry is incorrect u just need to shot those 2 points. You will see in the device manager on your computer once the board enters dfu mode it will load as mega 2650 do instead of just a mega 2650.
http://api.viglink.com/api/click?for...on%20ArduFlyer
http://www.rcgroups.com/forums/showp...postcount=1505
Old Mar 23, 2015, 10:20 PM
ten safe frogs is offline
Find More Posts by ten safe frogs
United States, NY, New York
Joined Aug 2005
I keep finding this thread when looking for APM/HKPilot SBUS info, and just want to clarify since it's kind of confusing:
Q: For the original question: How do you use PPM with HKPilot/APM?
A: Simply short inputs #2 and #3, and connect input #1 to the PPM out on your RX. That's it, it should work.
Q: How do you use an SBUS RX with APM/HKPilot?
A: Two options:
1) Buy a PPM to SBUS adapter, like this one: http://www.hobbyking.com/hobbyking/s...85&aff=1107187
Then connect the output of the adapter the same way you do a PPM RX (as described above)
2) OR, you can try to upgrade the PPM decoder on the APM/HKPilot board. There's a hex file floating around from somewhere (I haven't seen the code, and I'd like to see it if anyone has a link!) you can use to upgrade the APM/HKPilot board to directly support SBUS so you don't need the PPM/SBUS decoder.
To update the PPM decoder, you have to enter "DFU mode" on the APM/HKPilot board, there are instructions in the links above, along with a video showing how to update the board on a windows machine.
That should be it!
If anyone has instructions for entering DFU and upgrading the PPM encoder/decoder via a Mac, that would be awesome
ten safe frogs is offline Find More Posts by ten safe frogs
Old May 28, 2015, 04:51 PM
DRUMSZ is offline
Find More Posts by DRUMSZ
Joined May 2011
Apm rx connection
Hey all hope this tread is not dead
just got my micro apm x2 actually (hk type)all is working great full kit gps,telem ,,,,,,,,
but I can not figure out for the life of me how to get radio calibration
tryed the normal connections pwm I think and with the ppm module shorted pins 2,3 but nothing tried my pix-hawk rx set up with module that works and still nothing
pix-hawk using devo 8 chan Rx
orange 7 and orange 6 channel one of the 7 using satellite
any ideas or help thanks guy's
DRUMSZ is offline Find More Posts by DRUMSZ
Old Jul 26, 2015, 06:49 PM
everfree is offline
Find More Posts by everfree
Joined Dec 2013
anyone know how to setup sbus for frsky D4R-II (or ur call it PPM) any idea? i only know how to do that in min apm but not this board... the menu said "Cut and Short CH5" but not sure where to short it....any idea ? thx guys
everfree is offline Find More Posts by everfree
Old Yesterday, 01:59 PM
noodlemctwoodle is online now
Find More Posts by noodlemctwoodle
United Kingdom, England, Bristol
Joined Aug 2015
Here is the Hex, its hosted on Peter Kings google docs page
If we can learn how to get into DFU mode that would be awesome as I cant find anything for this board :-/
I have watched all the videos for the full size APM but the MK Micro doesn't seem to have a jumper 2 location or at least its not written on the board anywhere or in the documentation. Has anyone found a pin out diagram?
noodlemctwoodle is online now Find More Posts by noodlemctwoodle
Old Yesterday, 04:52 PM
Joined Aug 2015
Found this, directly quoted from the post
Comment by hector hind on February 8, 2015 at 2:08am
"Ok thought id post this to help anyone else wishing to update there PPM encoder
Jump to Ground
(see respective picture)
Then short these pads for a second to force it into dfu mode for flip"
Old Yesterday, 04:57 PM
Joined Aug 2015
Not sure what jump to ground means, any ideas?
Discussion HobbyKing Micro HKPilot (APM) iskess Multirotor Electronics 48 Aug 02, 2015 10:03 AM
Discussion HKPilot Mega 2.7.2 - Programming the ATMEGA32U2 szakacs Multirotor Electronics 0 Dec 29, 2014 06:37 PM
Discussion What FC To Use, So Many Choices - KK 2/5 APM HKPilot PX4 beem Multirotor Electronics 0 Dec 22, 2014 01:49 PM
Sold hkpilot apm 2.5, case, rctimer 915mhz telemetry, neo-6m gps 3d astronaut Aircraft - Electric - Multirotor (FS/W) 2 Jul 23, 2013 12:06 PM
Wanted APM 2.5 or 2.0 clone: Arduflyer, HKPilot, etc snowluck2345 Aircraft - Electric - Multirotor (FS/W) 6 Jul 15, 2013 06:14 PM
