Old Oct 05, 2014, 02:16 PM
seaspb is online now
Find More Posts by seaspb
building season is here.
seaspb's Avatar
United States, OR, Silverton
Joined Nov 2008
Help!
Rudder screw
What should I use to keep this (on the bottom of the AVA pro rudder) screw from getting loose? I keep snugging g it up, I've even tried loctite but still working its self loose.
seaspb is online now Find More Posts by seaspb
Old Oct 05, 2014, 02:29 PM
wakumann is online now
Find More Posts by wakumann
wakumann's Avatar
Canada
Joined Jul 2003
I would just use better fitted Loctite, or a tab of goop should do as well??
wakumann is online now Find More Posts by wakumann
Old Oct 05, 2014, 07:19 PM
seaspb's Avatar
Joined Nov 2008
i'm somewhat concerned about this because when it works itself loose the surface develops slop but when i get it too snug the surface becomes sticky and starts double centering.
is anyone else having this with their AVA?
I have used purple and blue loctite, a very small drop of blue as i didn't want to seize/fuse the thing together.
Old Oct 06, 2014, 07:14 AM
lesterpk is online now
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Same issue on the Supra Pro Comps. Remove the screw, a drop of lube in the thread, I used vaseline, and screw the screw almost home. Leave it about a half turn loose. Then a drop of 5 min epoxy on the head of the screw and onto the epoxy board to secure it. The rudder will continue to rotate on the screw threads.
lesterpk is online now Find More Posts by lesterpk
Old Oct 10, 2014, 02:47 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You might add a couple of notches into the edge of the screw head Sam, so that the epoxy can have a place to mechanically keep the screw head from rotating.
Sounds like an easy fix suggested by lester.
R,
Target
target is offline Find More Posts by target
Old Oct 10, 2014, 10:45 PM
seaspb's Avatar
Joined Nov 2008
I discovered the real issue today the hole where the screw gets thru is sloppy I installed a plastic bushing and loctite it's working true again. The whole time I thought it was working it self loose.
Thanks for the input guys.
Found Espada rudder screw vespa Aircraft - Sailplanes (FS/W) 6 May 12, 2014 03:12 PM
Discussion KK2.1 FC board Arming happens for left rudder instead of right Rudder Mahadeesh Multirotor Talk 3 Dec 26, 2013 02:31 AM
For Sale Servo screws in phillips head screws and cowl Screws unclegeorge Aircraft - General - Radio Equipment (FS/W) 0 Jan 06, 2012 09:20 AM
For Sale Servo screws in phillips head screws and cowl Screws unclegeorge Aircraft - General - Miscellaneous (FS/W) 1 Dec 30, 2011 10:34 PM
Help! Rudder is screwed? Heli keeps spinning on take off! Anderson2005 Electric Heli Talk 9 Nov 13, 2005 04:17 AM
