Old Oct 28, 2013, 11:43 PM
derpron is offline
Find More Posts by derpron
darn you, kakka carrot cake.
derpron's Avatar
Australia, WA, Perth
Joined Aug 2012
motor wire insulation alternatives
hey i have just rewound a bunch of motors and i dont have any more heat shrink left to insulate the copper wire leading off to the ESC.
has anyone tried hot glue or some sort of gap fill or sealant instead of heat shrink?
i was thinking of putting a coat of silicone sealant on the wires.
derpron is offline Find More Posts by derpron
Old Oct 28, 2013, 11:50 PM
WadesRC is offline
Find More Posts by WadesRC
Got Another Prop?
WadesRC's Avatar
United States, VA, Hampton
Joined Aug 2006
I have used this with mixed results but found heat shrink works best.
http://www.plastidip.com/home_solutions/Liquid_Tape
WadesRC is offline Find More Posts by WadesRC
Old Oct 28, 2013, 11:53 PM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Strictly speaking, you don't really need to cover them with anything since they're already insulated with an enamel coating. As long as you prevent them from scraping or rubbing against things (easy enough), you should be fine just adding a bit of heatshrink at the connectors and leaving the rest bare. I've got a few like this, and they're perfectly fine.
In my opinion, it's much nicer to chop off the winding wires at the stator and add some nice flexible wire leads. It's a little scary, but patience and care will get you through no problem. I've done plenty like this and haven't effed one up yet, so I guess that's a good sign
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Oct 29, 2013, 06:49 AM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use Goop around the wires where they come out of the motor if they're very flexible or look questionable. Hot glue wouldn't cut it when the motor gets hot.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Oct 29, 2013, 07:28 AM
derpron is offline
derpron's Avatar
Joined Aug 2012
ok thanks peeps.
ill keep em bare
Old Oct 29, 2013, 07:48 PM
elfwreck is offline
Find More Posts by elfwreck
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
Not that you need/want this but maybe tge next person ould use the info.
Liquid electrical tape works great for this.
I often use it on plug solder joints, so I have it around the shop.
RobII
elfwreck is offline Find More Posts by elfwreck
Old Oct 30, 2013, 10:38 AM
Chuck is online now
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
The little plastic coffee stir sticks will work in a pinch.
Chuck is online now Find More Posts by Chuck
Old Oct 31, 2013, 12:57 AM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Electrical tape would also work, or any other tape for that matter. As stated by others, the wires are already insulated, you really just need a little something to protect that coating.
If it is a small motor and weight is very important, leave it bare. I have a couple of tiny motors like that <5g and they are fine (the wire on those is scary thin though ).
desertstalker is offline Find More Posts by desertstalker
Old Oct 31, 2013, 05:19 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I have broken a few wires on the smaller motors with the smaller wire, break right where they come out of the motor and are soldered to the wires that go to the ESC. This is why I Goop them at the outlet of the motor to hold them a little more solid. Havn't broke one since.
Gord.
Discussion Lipo balance wire insulation failure rcalldaylong Batteries and Chargers 0 Apr 21, 2013 12:34 PM
Discussion Motor wire insulation removal rhodesengr Electric Plane Talk 5 Nov 26, 2012 11:01 PM
Discussion Alternative to liquid insulation tape for power distribution boards? David Jenkins Batteries and Chargers 9 Oct 10, 2011 06:23 AM
Discussion No wire sheath on 1515/2.5D/F/H motor - insulation damage new ? blueviewlaguna NeuMotors 0 Nov 24, 2007 09:38 AM
Silicon Insulated Wire AUSTRALIA ?? Squeezer Power Systems 16 Jul 28, 2004 01:24 AM
