Old Sep 16, 2013, 03:58 PM
Syncro is offline
Find More Posts by Syncro
United Kingdom, Walsall
Joined Mar 2013
ARX 540 spur/ pinion gear pitch.
Anybody know what pitch the spur and pinion gears are on an ARX?
Cheers.
Syncro is offline Find More Posts by Syncro
Old Sep 16, 2013, 04:11 PM
Syncro is offline
Joined Mar 2013
Think I've found my answer.
MOD1?
Old Sep 16, 2013, 06:29 PM
trf_414_m2 is offline
Find More Posts by trf_414_m2
Espa˝a, CL, ┴vila
Joined Sep 2008
A tip for you to check the spur module.
Measure outer diameter of the 56T spur....
For mod1 it should be 58mm (1mm per teeth plus another 2mm because the difference between pitch diameter and outer one is two full teeth)
In case that you have a 32DP or 0.8mm mod spur, outer diameter can be calculated same way than above but multiplying teeth number plus 2 by 0.8...
So 58 x 0.8mm = 46.4mm outer dia (pitch dia at 44.8mm).
Hope this helps.
Cesar.
trf_414_m2 is offline Find More Posts by trf_414_m2
Discussion Pede 4x4 Pinion vs Spur Gear superFlint Off-road Cars 6 Sep 19, 2013 12:06 AM
Wanted Brushless Pinion/Spur Gear akertulis Cars - Trucks and Parts (FS/W) 0 Jul 01, 2013 01:32 PM
Question SC10 4x4 - 32 Spur gear / pinion selection?? Mad Matt Off-road Cars 2 Jan 21, 2013 10:27 AM
Help! ARX pinion/spur mesh question 61DUB Motorcycles 5 Jul 06, 2009 12:42 PM
For Sale 48 Pitch Pinion&Spur Gears for EP 1/10th. R_JOB Cars - Cars and Parts (FS/W) 0 Feb 14, 2006 03:57 PM
