Old Feb 09, 2013, 07:57 AM
carlostomasso is offline
Find More Posts by carlostomasso
carlostomasso's Avatar
Joined Feb 2010
I did re-bind my plane, and replaced the white silicon holding the ar 635 in the fuse with nice velcro. I think it was just not properly bound, the plane is jittering a lot less now & I think it should be much better now. Even full trottle the ailerons moved just slightly correcting the air from the prop. This was just a home, ground test, but looks much better now. Will let u know after i remaiden
Thanks all and sorry to waste time with a nob error, i was willing to fly this plane before it arrived and probably did not focus at all while binding!
T
carlostomasso is offline Find More Posts by carlostomasso
Old Feb 09, 2013, 08:59 AM
MalcolmS is offline
Find More Posts by MalcolmS
MalcolmS's Avatar
United Kingdom, England, London
Joined Jul 2007
T
Glad you appeared to have sorted it Tomas. Will after have a dual Visionaire flying session soon
MalcolmS is offline Find More Posts by MalcolmS
Old Feb 09, 2013, 09:32 AM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Maidened mine today, in 20 deg F and 10-12 mph winds
After 3 batteries, my thumbs was too frozen to fly 3D so I did a last battery in sport mode cruising around.
What a plane! It makes me look so much better than I really am, and it is such a confidence booster that I was doing hovers with tail touches and rolling harriers within the first 3 minutes flying it!!
KaiWE is offline Find More Posts by KaiWE
Old Feb 09, 2013, 11:03 AM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
If you put it in sport mode for the last battery, have you compared general flight mode with sport mode to see how much differently it reacts? Standard gain is quite a bit higher in sport mode, but haven't decided how much trouble it will be to reprogram to sport mode at the field and wondering how much difference it makes.
bobly is offline Find More Posts by bobly
Old Feb 09, 2013, 11:05 AM
Sonofagun is offline
Find More Posts by Sonofagun
J. Titors Gr Gr Grandpappy
Sonofagun's Avatar
Charlotte,NC
Joined May 2005
I agree, if everyone else's flies as well as mine... words gonna get out and they are gonna sell a million of these things.
Sonofagun is offline Find More Posts by Sonofagun
Old Feb 09, 2013, 11:13 AM
Sonofagun's Avatar
Charlotte,NC
Joined May 2005
Bobly, try QuiQues instructions posted earlier. Start in sport 100 percent, fly around, get feel for it. Switch to 3d when trims sorted and altitude. She's stable and you will have fun if you don't overthink it. Parts are avail and inexpensive. You just saw a crazy guy maiden in a parking lot in a blizzard. No excuses... get out and fly !
Old Feb 09, 2013, 11:15 AM
indyrcpilot is offline
Find More Posts by indyrcpilot
United States, IN, Indianapolis
Joined Jan 2003
Originally Posted by KaiWE View Post
Well, in HorizonHobby terms that is a BnF (Basic) and they do those as well...
Yes, a BNF Basic version is what I'm hoping for.
I want the new receiver, but don't need the battery/charger.
Chuck
indyrcpilot is offline Find More Posts by indyrcpilot
Old Feb 09, 2013, 11:27 AM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
QQ was talking about flying in General Flight (pos 0) at first, not Sport mode.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Feb 09, 2013, 11:36 AM
Sonofagun's Avatar
Charlotte,NC
Joined May 2005
I stand corrected. The point was to follow the already posted instructions and give it a try. I Left the ground and have been on 3d mode and full rates since 20 seconds into 1st flight. Haven't really had to think about switches since. Only changes to stock setup so far is to ad 5 percent expo to rudder, move clevis to lower hole on elevator, and a prop change. Total cost $3.00. If you follow the setup instructions for your tx it flies really well out of the box. At least mine did.
Old Feb 09, 2013, 11:39 AM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Have flown to little to give a good comparison between sport mode and general flight mode...
But the procedure to switch between 3D and Sport mode is no biggie - for my mode 2 DX8, I just set the throttle (left) stick at center and hold the right (aileron/elevator) stick in the lower left corner while powering the receiver to go form 3D to Sport, upper right corner to go from Sport to 3D...
Old Feb 09, 2013, 11:48 AM
windrnone is offline
Find More Posts by windrnone
lownslow
windrnone's Avatar
United States, FL, Cape Canaveral
Joined Nov 2011
Which raises a not so dumb question, if you have changed the gains from the factory settings will going back and forth from sport mode to 3D mode reset the gyros back to the factory settings??????
windrnone is offline Find More Posts by windrnone
Old Feb 09, 2013, 12:09 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Was wondering the same - have not changed any gain settings yet, so I had nothing to loose trying out the Sport mode...
Since there is a separate procedure for resetting the gain values to factory default, I would guess that the values are kept while changing modes, but that remains to be confirmed - HH guys?
Old Feb 09, 2013, 01:14 PM
tourist_603 is offline
Find More Posts by tourist_603
Joined Dec 2007
Addtional Batteries
I plan to buy two more batteries for the VA. I will convert the connectors to Anderson Powerpoles, so whether or not the battery comes with connectors is unimportant. if I get a higher C rated battery, can I use a smaller size, perhaps 2000 mah or 1800 mah, knowing that I'll be sacrificing some duration, but still getting full performance? What have you had success with/recommend?
tourist_603 is offline Find More Posts by tourist_603
Old Feb 09, 2013, 02:00 PM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
Good move. I convert all my stuff to APP also just to have a std connector base. I am slightly doubtful on the posted C rating on most batts these days, your milage may vary.
wjs is offline Find More Posts by wjs
Old Feb 09, 2013, 02:53 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I also use APP on all my stuff. Nice and easy.
turnerm is offline Find More Posts by turnerm
Discussion Parkzone's New Habu 2 EDF ChuckTseeker Foamy EDFs 4664 Today 06:06 AM
For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2012 12:26 AM
Sold New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 23, 2012 09:10 AM
