Old Jun 18, 2015, 02:28 AM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
Originally Posted by marksp View Post
Now I have the PR Bushwheel shock struts. They work great and can't see ever needing to change or replace. The downside is the price, but I'm happy to have them.
Just wish they were around before wasting my time and money on all the other failed solutions! Would have also saved a few flying days that were cut short because of gear failure.
$95 is pretty cheap insurance in my books one could damage their plane if the rubber bands pinged when landing I asked around and everybody said rubber bands were crap so when i was looking for some bush wheels and found the struts too my worry was over!
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Jun 18, 2015, 04:06 AM
tupelo is online now
Find More Posts by tupelo
tupelo's Avatar
Finland, Uusimaa, HKI
Joined Feb 2008
Will give these a try. Around the size of a manīs wrist. More flexible than O-rings, but less than normal rubber band.
tupelo is online now Find More Posts by tupelo
Old Jun 18, 2015, 08:23 AM
marksp is offline
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
For the record when using rubber bands, generally when 1 or 2 fail you'll notice the sag before complete failure, so no real concern for damage. It's just a hassle to have to replace so often.
marksp is offline Find More Posts by marksp
Old Jun 18, 2015, 07:19 PM
tupelo's Avatar
Joined Feb 2008
How do the PR Bushwheel shock struts work? Is there a spring inside them or something else?
Old Jun 19, 2015, 08:33 AM
marksp is offline
marksp's Avatar
Joined Apr 2011
Spring
Old Jun 20, 2015, 04:25 PM
tupelo's Avatar
Joined Feb 2008
Has anyone programmed Futaba 8FG Super for the Super Cub? I would like to have two-stage flaps and elevator mixed to the flaps so that there is some down elevator on mid flaps and some more on full flaps.
I used the motor function to slow down flaps, and I have only managed to program down elevator on full flaps. None on mid flaps.
Old Jun 20, 2015, 07:24 PM
marksp is offline
marksp's Avatar
Joined Apr 2011
Might also consider programming in some aileron differential while you're at it.
Old Jun 21, 2015, 06:33 AM
barracudahockey is online now
Find More Posts by barracudahockey
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Word of advice, the SC needs a healthy dose of down at both stages but especially full flap, to the point that dropping full flaps w/o elevator comp will result in a loop.
Not trying to scare you, just prepare you.
As for the Futaba radio, can't help you from recent memory but you might tinker with the offset on the mix that should slide the start point from mid switch to top of the switch but it's been a while
barracudahockey is online now Find More Posts by barracudahockey
Old Jun 21, 2015, 07:15 AM
tupelo's Avatar
Joined Feb 2008
This is how my flap/elevator mix is done on my Futaba 8FG Super. Motor (virtual channel) is master to both flap and elevator as it is possible to slow down the servo movement that way.
Flap is connected to three-position switch and works as intended. The mid servo position is mid flap, the other "turned" servo position is up flap and the other "turned" position is full flaps respectively.
The elevator is a problem because the movement in the mix must be 0 to the other direction so that there is no up elevator. I just haven't found a way to adjust 5mm push on the elevator on mid flaps and 12mm on the landing flaps.
At the moment, as said, there is no push on mid flaps and some on full flaps.
Any help would be greatly appreciated.
Old Jun 21, 2015, 07:22 AM
Joined Sep 2004
I'm too tired from being out in the sun for 3 days to analyze why you're using the motor as the master but you need to change the offset
offst as its displayed there.
You want to offset the start point of the mix.
Old Jun 22, 2015, 04:43 AM
tupelo's Avatar
Joined Feb 2008
Hi
The motor is the master because that enables me to slow down the servos when flaps are deployed. The instruction I used is here:
http://www2.ripmax.net/Futaba_Inform...Servo_slow.pdf
I will try to alter the offset once I get back from summer cottage. Although I think I did try that already.
Old Jun 25, 2015, 06:17 AM
tupelo's Avatar
Joined Feb 2008
Asked for instructions from Futaba and got them!
I was told to get rid of the motor as master function as "mixing to the motor digital channel messes the elevator up too much."
Did that and made this mix as per instructions and at least on the "servo" screen it looks good. I just needed to replace the "OFF" on the second page with a "+" so both elevators work in the mix.
Old Jun 25, 2015, 07:23 AM
Joined Sep 2004
Yea, that never made any sense anyways.
Old Jul 14, 2015, 08:27 PM
tupelo's Avatar
Joined Feb 2008
Upgraded my Cub with the custom shocks from PR Bush Wheels. They work a treat! Money well spent.
Also customer support was top notch.
Build Log Dare Design 60" Piper Super Cub PA-18 AmpAce Scale Kit/Scratch Built 1081 Sep 24, 2012 07:06 PM
FlyRC mag PA-18 Super Cub pull out plan build Canada Goose Parkflyers 371 Jul 15, 2012 06:25 AM
New Product 16%off-Dynam Super Cub PA-18 4-Channel 2.4GHZ PNP RC Airplane@Focalprice.com Santoyo Hot Online Deals 0 Jul 09, 2012 08:34 PM
For Sale Dynam Super Cub PA-18 4-Channel RC Airplane for sale! Santoyo Aircraft - Fuel - Airplanes (FS/W) 4 Jun 02, 2012 09:07 PM
Discussion Dynam (Hobby King) Piper Super Cub PA-18 - which replacement motor? romandesign Foamies (Kits) 2 May 28, 2012 01:41 PM
