Old Nov 04, 2011, 07:10 AM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
Arowana
Excellent deal for a novice or someone in the mood for a rebuild.
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old Nov 04, 2011, 07:40 AM
mike__ is offline
Find More Posts by mike__
Perth, Western Australia
just got the email
bargin!!!
the epoxy version too
mike__ is offline Find More Posts by mike__
Old Nov 04, 2011, 09:17 AM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I can't speak highly enough of the Arowana. Had mine a few years now & it is still going strong. The gel coat has some hairline cracks but that's the result of quite a few big 45mph tumbles.
I usually run an 8Xl motor in it but I'm trying one of these in it now.
http://www.hobbyking.com/hobbycity/s..._Inrunner.html
785boats is offline Find More Posts by 785boats
Old Nov 05, 2011, 12:26 AM
mike__ is offline
Paul: is that the hi-model 8xl? Let us know how that motor runs. Was thinking about one of those on 4s or ordering some 6s packs and a 1400kv version
Been enjoying mine for 1 1/2 years running one of those typhoon 500's on 4s with a 45k prop.
Old Nov 05, 2011, 06:05 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Yes Mike. that's the one.
A great motor. It's actually an FSD (Feisuda) motor under the Hi Model brand.
I run an X440/3 prop with it. Allows the motor to rev & keeps the temps around 40-45C
I also run it in the 33" Hydro turning an ABC H-5 prop.
I've got a couple of those Typhoon Motors too. My favourite prop on it is a Prather S220 but that's only in a 25" hull not a big 32" one like the Arowana. How are the temps with the K45 prop?
I think the motor that comes with the Arowana is also an FSD motor.
Old Nov 05, 2011, 07:47 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
That's a really good deal! I'm tempted to buy a couple just to have around!
wparsons is offline Find More Posts by wparsons
Old Nov 05, 2011, 08:57 AM
mike__ is offline
Saw youtube footage of your typhoon 500 / 25" mono, hauls along!
Don't have a temp gun but after 6min+ its on the high side off warm. You can keep your hand on it without it being too hot. If theres a low ambient temp (~18deg for perth) then its a little cooler. Have a w/c mount / straight shaft setup on bearings.
What timing are you running with the typhoon out of curiosity? have the 80a turnigy plush set on medium, which is 15/17deg?
Am curious to try a tenshock m4 metal prop with it (as jan suggested too me) but now wondering how one of the graupner 440/3's would go.
Cant seem to find the 8xl on the hi model page, i swear though you provided a link to it in the past. Maybe they dont stock it anymore.
Old Nov 05, 2011, 09:26 AM
mike__ is offline
DrifterS Turnigy 500 Outrunner 4S with a new X645 (0 min 57 sec)
typhoon did a nice job powering this cat!! motor would have been fairly hot though with the 645 prop? that cat looks like a similar size if not a little smaller than the arowana
Old Nov 05, 2011, 12:45 PM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Mike.
So You can get 6 minutes with the Typhoon in the Arowana with the K45 prop? Man that's good going. Don't think you will be able to with the 8Xl even with a smaller prop. although I've never tried it. Here's the link to it at Hi Model.
http://www.himodel.com/electric/2075...0_3674-8T.html
I run 15 degrees on the Typhoon & the Xl type motors.
Pete's Drifter S is 26" I think, but the X645 prop certainly put a lot of heat into the motor. Found an M445 to be a better prop.
Old Nov 06, 2011, 01:26 AM
mike__ is offline
Thanks for the link / info Paul. I think i may have to order one. Do you know how they compare to the identical leopard? What sort of runtime do you get with a 5000 pack & a x440/3?
Yeh with the 45k prop (never bothered trying the 42k). I have x2 2650mah 30c turnigys in parrallel. After 6min of nearly continous full throttle with little stop / starting i was putting back 70-75% into each pack. Lately though im putting back less and it seems a little slower, i think the packs are showing there age. The driveline has v little friction which probably helps.
Have some 6000mah 2s packs on the way which have been sitting in zurich for 2 weeks! damm u swiss post
Old Nov 06, 2011, 02:03 AM
785boats is offline
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Nike.
The run time with the 8Xl & 440/3 prop is 3 to 3-1/2 min at best.
A 5 lap race plus mill lap & slow down lap is about 1-1/2 to two min long & I have about 30% left in a 5000mah 45C pack.
Not sure about the Leopard.
I did run it today with a Leopard 3674 2200kv 4 pole Leopard spinning an ABC 442/3 prop
& it was quick & stable in some pretty choppy water after I dropped the turn fins deeper & lowered the trim tabs another degree or so.
Temps & battery usage was about the same. Probably only slightly faster than the 8Xl & 440/3 combination.
Old Nov 06, 2011, 08:15 AM
mike__ is offline
ahhh, fair difference then, but then my boat probably does 37ishmph compared to your 45. Nice work with the new motor
Discussion ***AROWANA 31.5" DEEP-VEE MONO*** fleetmaster Racing Boats - Electric 655 Jun 18, 2014 05:47 AM
Discussion Help me choose - Mini-Arowana or Upgraded Prince FoamCrusher Racing Boats - Electric 21 Oct 29, 2011 12:34 PM
For Sale EP Fibreglass Mono 2 Deep-vee Arowana Racer Racing Boat t161 Boats (FS/W) 0 Jul 30, 2011 08:10 PM
Poll R2Hobbies Deep-vee Arowana Vs. Mini Cat velocity Mono RChelisrule Racing Boats - Electric 31 May 06, 2011 10:39 AM
Discussion 22.5" arowana hull hazegry Racing Boats - Electric 32 Sep 07, 2010 03:59 AM
