Old Sep 26, 2011, 07:38 PM
jafo150 is offline
Find More Posts by jafo150
Joined Sep 2011
crossing brands
Not sure if this is the right area but here goes
ive flown a long time but never mixed brand names in servos/receivers
can i safely use hitech servos with a futaba receiver? Not 2.4 and IS dual conversion.
thanks in advance
jafo150 is offline Find More Posts by jafo150
Old Sep 26, 2011, 08:05 PM
evaristus is offline
Find More Posts by evaristus
Joined Jan 2009
Yes you can use hitec servos on futaba receivers, I always do when flying 1/2a and lekkies.
Good flights
Evaristo
evaristus is offline Find More Posts by evaristus
Old Sep 27, 2011, 02:44 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Most servos are built to a technical standard these days, so can be used with any other manufacturer's radios -- whatever the frequency or channel. Like evaristus, I use a lot of Hitec servos with my Futaba radios, but I also use several other cheaper brands in my smaller models.
I believe you get what you pay for, so I use Futaba and Hitec in my larger models but, having said that, I've never yet had one of the cheap ones fail on me.
abenn is offline Find More Posts by abenn
Old Sep 27, 2011, 07:40 AM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
I think that all presently available servos will work in all brands of receivers. The one thing you may have to do is to remove the little key tab on Futaba servos so they will fit into other brand receivers. Most have a universal plug (no key like Futaba has) so a direct fit. The one exception is the very old style Airtronics as they were a wider connector as well as having the + and - leads interchanged. The newer Airtronics conforms to the general convention of connector and polarity.
Rodney is online now Find More Posts by Rodney
Discussion which brands of rc lipo batteries do you often like? wlnlz2005 Chit Chat 5 Nov 07, 2011 10:11 AM
Discussion Mixing motor brands with same kv.... power Multirotor Talk 0 May 02, 2011 04:21 PM
Found 60 amp ESC (one of the many HW brands) melsailsnorth Aircraft - Electric - Power Systems (FS/W) 1 Apr 25, 2011 05:07 PM
Discussion I'm after a digital rx switch, what brands are out there? dwalk Power Systems 5 Apr 20, 2011 01:59 PM
Discussion Compatibility between radio brands InTheLift Radios 5 Mar 07, 2011 04:24 PM
