Old Sep 11, 2011, 05:42 AM
Magickid is offline
Find More Posts by Magickid
Wizard
Magickid's Avatar
Australia, QLD, Brisbane
Joined Jul 2011
Which motor 5g or 10g :confused:
Guys help me choose, i need a motor for my foamie http://www.rcgroups.com/forums/showt...4#post18666120
im going to use a 370mah 2s lipo, 3 3.7g servos, a 6a ESC and an aproximately 5-7g reciever. which motor should i use? the Hobbyking 5g or 10g?
this is the 5g - http://www.hobbyking.com/hobbyking/s...er_2000kv.html
this is the 10g - http://www.hobbyking.com/hobbyking/s...nner_10g_.html
i dont want imense speed or anything just something to fly around my yard. But i do want to put this motor into a Bipe later on.
thanks
Magickid is offline Find More Posts by Magickid
Old Sep 11, 2011, 07:49 AM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
According to the size and weight of the equipment you have you'll be better off with the 10g motor. What's the wingspan of your plane?
TODD
I R Irv is online now Find More Posts by I R Irv
Old Sep 11, 2011, 03:01 PM
MrHmmm is offline
Find More Posts by MrHmmm
Multi discipline RC'er
MrHmmm's Avatar
Netherlands
Joined Aug 2005
I second that opinion! (maybe even 15g)
MrHmmm is offline Find More Posts by MrHmmm
Old Sep 11, 2011, 07:25 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
one thing to keep in mind is the AUW and the thrust to weight ratio. 50% thrust to weight will theroeticly fly, but you will spend all your time at WOT. a plane that has close to 1:1 thrust ratio can cruise at half throttle.
so keep this in mind when choosing a power plant.
nemoskull is offline Find More Posts by nemoskull
Old Sep 11, 2011, 07:51 PM
Magickid is offline
Wizard
Magickid's Avatar
Joined Jul 2011
60cm wingspan
Old Sep 16, 2011, 02:52 AM
meshyx is offline
Find More Posts by meshyx
meshyx's Avatar
Norway
Joined Feb 2010
With a 60 cm wingspan, I would definitely go with the 10g motor. The 5g motor would look ridiculous, and your plane can certainly carry the extra 5 grams. I would consider getting a 15 to 20 gram motor as well, since they are so cheap.
meshyx is offline Find More Posts by meshyx
Old Sep 16, 2011, 04:08 AM
Magickid is offline
Wizard
Magickid's Avatar
Joined Jul 2011
ok thanks everyone. also the plane im building i will later make more of to sell!
http://www.ultimaterc.com/forums/sho...78#post1138578
sorry for the link on another site
For Sale 9g, 6g, 2.5g, and 1.5g linear servos -- All NIB Garret H Aircraft - General - Radio Equipment (FS/W) 2 Sep 12, 2011 11:41 PM
Discussion New and confused - spek 7 or 8 or? RCWarbirds Radios 18 Apr 06, 2011 07:01 PM
Found hobbycity AD-C5 or similar 5g brushless motor habitforming Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 24, 2009 10:22 AM
Wanted Looking for 9-10g motor, 3-5g servos, 250-2S lipo-where to buy? JoeR Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 12 Nov 07, 2007 05:30 AM
Im confused on which motor to upgrade my tigermoth with? chargin Parkflyers 1 Feb 05, 2003 08:32 AM
