Latest blog entry: Chaos 600 ESP build
Joensuu, Finland
Joined Mar 2002
Treshold, Azarr, JPF: thanks for the insight. As you can see, I'm not familiar with that type of planes and wasn't aware that they could have such a strong yaw-roll coupling. Learning something new every day.
Ryanp15: see below. Just play with the settings and observe the result. Change only one parameter at a time. Rate - this sets the amount of movement sent to the slave channel. If set at 100%, full stick gives full movement on the slave channel. If set at 50%, full stick gives only 50% of full movement on slave. Naturally the master channel remains unaffected. Offset - this lets you adjust centering of the slave channel while the mix is active. Trim - is an on/off type of setting. It selects if the trim lever of master channel has an effect on slave channel or not. ACT = active, INH = inhibited. |
| Thread Tools | |
| Discussion Really confused on elevon mixing on my 9x. | Koo | Radios | 0 | Aug 02, 2012 07:46 PM |
| Discussion What are y'alls shipping times? Ordered on monday still hasn't shipped? | elcid79 | HobbyPartz.com | 4 | Jul 25, 2012 11:26 AM |
| Question Calibrating Throttle on ESCs--One by One or All at the Same Time on a Quad? | Dave8888 | Multirotor Talk | 2 | Jan 29, 2012 08:16 PM |
| Discussion Dow Jones closing in on all time high... | rumme | Life, The Universe, and Politics | 33 | May 06, 2006 03:31 AM |
| Current on tailmotor 8V all the time? | zelicx | Micro Helis | 4 | Aug 17, 2004 02:41 PM |
