Old Jan 24, 2006, 09:11 PM
MI
Joined Mar 2005
Triton Competitor?
Does the Triton have any competitors that can charge up to 28V and also charge lipo's, nimh, nicd, and pb acid batteries? I'm in the market for a charger and would like it as flexible a charger as possible. Thanks.
Benaiah is offline Find More Posts by Benaiah
Old Jan 24, 2006, 10:47 PM
Now with more COWBELL!
U2Steve's Avatar
United States, KY, Lexington
Joined Mar 2001
If you're competing on features alone, I think the high-end Orbits and Schulzes play in the same ballpark. But then the Triton stomps everyone when you look at price as well.
U2Steve is offline Find More Posts by U2Steve
Old Jan 24, 2006, 10:51 PM
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
https://ssl.kundenserver.de/s4222101...%3D280606%3D29
http://ecsvr.com/RC-Direct/shopdispl...s+%2C+Chargers
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Jan 25, 2006, 05:42 AM
MI
Joined Mar 2005
Thanks for the info guys. I've been looking at chargers and for the money I couldn't find a competitor to the triton. I sure liked the Schulze, but it's out of my price range.
Old Jan 25, 2006, 09:28 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Here you go.....this one does the same for cheaper....
http://www.allerc.com/product_info.p...oducts_id=1872
Old Jan 25, 2006, 11:16 AM
MI
Joined Mar 2005
Mike, I like that charger alot, but it only charges up to 16.8V vs. the triton's 28V. I'm looking for the most flexible charger I can find for less than $150.
Old Jan 25, 2006, 02:24 PM
El Cajon, CA, USA
Joined Feb 2001
Plus the charger above can't discharge batterys at any real rate....no fan or heatsinks.
I have his brother (same charger different labels)
Daniel
Munch is offline Find More Posts by Munch
Old Jan 25, 2006, 02:35 PM
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
The Triton is a good charger, but it will only charge lipos at 2.5 amps max. This takes forever to charge packs around 4000 mah and over. If all your packs are smaller, it should work fine for you.
Doug
unbalanced prop is offline Find More Posts by unbalanced prop
Old Jan 25, 2006, 02:39 PM
pda4you's Avatar
Joined May 2002
OK how about this one?
http://www.allerc.com/eos7i.htm
Old Jan 25, 2006, 02:40 PM
MI
Joined Mar 2005
Munch, thanks for the input on that charger.
Old Jan 25, 2006, 02:43 PM
MI
Joined Mar 2005
Mike, somehow I overlooked that charger! I've got to check that one out. Thanks.
Old Jan 25, 2006, 03:50 PM
Florida
Joined Aug 2004
I have both the Triton and Hobbico Elite. Both are very good, each with it's individual advantages/disadvantages. In many respects the Elite is better as it will work either on AC or DC and will do two batteries (can each be a different kind with different requirements) at once, will either discharge, charge or cycle up to 3 cycles with setting of your choice on cell type, no. cells, discharge voltage etc. The Elite can also be set to lower charge rates for putting in the proper forming charges while the Triton's minimum rate is often to high a value.
Rodney is offline Find More Posts by Rodney
Old Jan 25, 2006, 04:08 PM
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
At 21 volts (which is it's max) that charger will do almost 6 Amps.
The Other Dave is offline Find More Posts by The Other Dave
Old Jan 25, 2006, 04:30 PM
Builder and Flyer
Brisvegas
Joined Jul 2004
I have one of these. Works great.
yakman is offline Find More Posts by yakman
Old Jan 26, 2006, 06:07 AM
Fredericton, NB Canada
Joined Nov 2003
The specification for this charger says 1-25 NiCd which is a lot more than 21 V!.
Ross Kean is offline Find More Posts by Ross Kean
