Old Jan 07, 2005, 08:58 PM
Joined Dec 2004
Cool
Hop Up A Wave Shark
Got A New Wave Shark For Me Wife
Add #12 Wire And Deans Plugs
Adding Water Cooling For The Motor
Question Is
Adding The 3mm Water Intake To The Bottom Ofthe Boat
It Came From Offshore Elect., Do's And Don't Of Drilling Hole In The Bottom Of Boat,what Kind Of Sealing Do I Need
Thinks Dennis
RACENUT44 is offline Find More Posts by RACENUT44
Old Jan 07, 2005, 09:17 PM
Dragon Slayer
ropanach's Avatar
Shelton,WA
Joined Nov 2004
I assume the intake tube is nyoprean, drill the hole for the tube smaller than the tube. Heat the tube in hot water force it through the hole more than needed, then let cool and cut back to what you need, the tube should seal itself, but for added protection, on the inside, use rtv sylicone, witch will remain flexable, I've not tried it my self, but I've seen it done, and it worked, but there maybe something better out there, this is just a suggestion. "LOL"
ropanach is offline Find More Posts by ropanach
Old Jan 07, 2005, 11:20 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Looks nice! Did you do the paint job?
As for water cooling pickup, I used a brass tube in the rudder strut. I drilled a hole directly forward in the transom above the water line to enter the interior. I drilled a hole on the side of the hull above the water line for the discharge tube. I sealed the tubes in the hull with slow CA glue.
PS: Don't use CA accelerator on this hull. Last picture shows why!
Kmot is offline Find More Posts by Kmot
Old Jan 08, 2005, 04:57 AM
Joined Dec 2004
Hi
Thanks For The Replies
The Paint Color Matchs Our Big Boat, Yes I Did Paint It
Brass Pick Up On The Back Is The Right Idle,nitro Wave Shark Has That,
If You Had The Cen Part Number I Will Go That Way.
Im Go To Try A 3/16 Brass Tubing Form Hobby Shop.
If Thats Your Wave Shark, Good Job, What Esc Is That
Look For One.
I Also Have The Hopup Prop, But Will Put On Later
Thanks Dennis
Old Jan 08, 2005, 01:19 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I just added my own brass tube. I don't know what any CEN part number is but Steve at Offshore surely will. My esc is an Mtroniks I got from Hobby People.
Old Jan 08, 2005, 08:49 PM
Joined Dec 2004
Thanks For Your Help
Will Have Some Pictures In Water Soon
I Also Have A Oavl Master 26 Im Working On
Old Jan 09, 2005, 12:29 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
No prob! If you are intersted in some in the water pics and video of mine, let me know.
Corona Main Shaft Hop Up Royal Electric Heli Talk 4 May 15, 2002 09:49 PM
Wanted Sky Scooter Pro. with all "hop-up" ready ddedicate Aircraft - Fuel - Airplanes (FS/W) 6 Mar 20, 2002 08:19 PM
TJ hop up help flyinryan Foamies (Kits) 2 Sep 23, 2001 11:34 AM
Hop up on my Wind star EP ChrisFeole Electric Sailplanes 6 May 22, 2001 09:21 PM
LMH hop up parts pmurray Electric Heli Talk 3 May 07, 2001 09:38 PM
