Old Sep 09, 2014, 09:44 PM
Hex Heads, Hex Heads!!!
United States, IL
Joined Oct 2011
Question
Hitec X4-Eighty Power Supply?
Hello all,
Recently pickep up the Hitex X4-80 charger. I must say I am looking forward to the upgrade from only charging one battery on my old hyperion to charging multiple batters at once. However, I find myself in need of a power supply. I am aware of the criteria needed for one, but despite thorough forum lurking I have been unable to find anything that people suggest. Can anyone provide and insight? Thanks.
-rt
rtbreeder is offline Find More Posts by rtbreeder
Old Sep 10, 2014, 03:21 PM
United States, IL
Joined Oct 2011
Bump
Old Sep 11, 2014, 07:24 AM
Barbados
Joined Jan 2011
Presuming the charger is a 50watt quad = 200watts.This will work with room to spare 360 watts.
http://www.ebay.com/itm/12V-DC-30A-3...item3cd0ab2b76
The Tug is online now Find More Posts by The Tug
Old Sep 11, 2014, 09:22 AM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
The combined maximum output of all four channels is 200W. Consequently, that would be the theoretic minimum input you'd need from a power supply, but electrical circuits never work at a perfect 1:1 input/output ratio. There are always losses and it's widely recommended that you choose a PS that can deliver at least 120% of a charger's total output.
Hitec's recommendation for this charger is an 1118 V DC power supply with a minimum amperage rating of 20 amps. 11V at 20A is 220W which is 110% of the theoretic minimum input requirement. 18V at 20A is 360W which is 180% of the theoretic requirement (200W).
I'd choose the 18V option because the extra power could be used to power another small charger, but if budgetary constraints are an issue you could also look at this option:
18V at just 12A is 216W which, for all practical purposes, is as good as 11V at 20A for driving the charger because circuit loss in chargers almost always goes down as the input voltage goes up. In other words, if you can find a good deal on an 18V power suppply that puts out at least 12A it will be a good match for your charger.
But more is always better.
Pete
PGR is online now Find More Posts by PGR
Old Sep 11, 2014, 11:59 AM
So. Cal.
A converted server supply of at least 400 watts would be the most cost effective solution and allow you to operate your charger at full output with headroom to spare.
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 11, 2014, 12:17 PM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
The version the OP mentions is an 80W charger, not 50W, 320W total. As Mark said, 400W would be fine.
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 11, 2014, 03:27 PM
United States, IL
Joined Oct 2011
Azarr
Thanks Azzar and everyone else for your input. THE charger is 80w per port totaling 320w all together. Would anyone care to recommend or link me to a PS that is compatible, that perhaps people who use this charger use?
At the moment, I am thinking about the Venom 350w PS
http://www.horizonhobby.com/products...supply-VNR0666
HH says it is discontinued, but the LHS can get it. My only fear is that this is a 25 amp PS BETWEEN the two ports, accounting for 12ish amps for port. Can anyone chime in?
Thank you!!
Old Sep 11, 2014, 05:31 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by rtbreeder View Post
....12ish amps for port...?
Thank you!!
Sure sounds like it from the description.
I would get something like this ten times over the Venom:
http://www.ebay.ca/itm/HP-Compaq-400...item1c3091c945
davidmc36 is online now Find More Posts by davidmc36
Old Sep 11, 2014, 08:45 PM
United States, IL
Joined Oct 2011
Hey guys, appreciate your imput.
Was at the LHS today, and was recommended the Hitec ePowerBox 30-Amp.
http://hitecrcd.com/products/charger...supply/product
Should be in on Tuesday. I'll report back with how it works. Thank you for all of your help!!
PS- Looking into getting a better PS like the ones recommended later on, will use this for now.
-rt
Old Sep 11, 2014, 11:36 PM
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
<facepalm>
I'm so "programmed" to discuss the old X4 (which I have) that I missed that.
Pete
Old Sep 12, 2014, 05:51 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
....will use this for now.
-rt
If that power supply is set up, which it appears to be, as simply having two parallel sets of outputs and you can pull 18V/30AMPS from one set of output posts, I don't see you ever needing anything different for that charger.
Nice unit with the LCD display, see what's going on at a glance.
How many beans they gonna ding ya for that?
Old Sep 12, 2014, 07:45 AM
United States, IL
Joined Oct 2011
I work there, So I get a discount. Whosale+10%. 101 for me, tax included. It looks pretty good. Thank you for all of your help!!
Old Sep 12, 2014, 08:04 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Pretty nice bit of kit for a hundred beans.
Old Sep 16, 2014, 09:09 PM
United States, IL
Joined Oct 2011
Well, everything showed up today and is working as expected- Fine!! My only comlaints are the following:
1) The fan on the charger goes on and off every few seconds
2) The PS does not show the amount of amps going out. (At least not accurately)
For Sale New-In-Box Hitec X4-Eighty Charger LBMiller5 Aircraft - Electric - Batteries & Chargers (FS/W) 8 Aug 04, 2014 11:43 AM
Sold Hitec X4 Multi-Charger w/ 13.8v 20A Pro Peak Power Supply - $170 speedster239 Aircraft - Electric - Batteries & Chargers (FS/W) 8 Jan 07, 2014 10:57 PM
Sold Charging station = Hitec X4 + 46 Amps power supply MarLi Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 29, 2013 09:08 PM
Sold Hitec Multi Charger x4 80 Eighty Charger vhoward1122 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Dec 23, 2013 09:22 AM
Discussion Help!-Hitec X4 Eighty Problem charging Lipos flyboy52 Batteries and Chargers 6 May 08, 2012 07:20 PM
