Old Aug 04, 2014, 09:26 PM
Joined Sep 2011
A60 6xs V2 with X-110 Opto
So here is the setup
•Hacker A60-6XS V2 High-End Brushless Motor
•Hacker X-110 Opto Sensorless Electric Speed Controller
•Lightweight Aero-Model 5000 mAh 6 Cell 22.2V Battery Pack
•APC 20*11 Electric Prop
With factory default on the ESC, I get a squack when I hit the throttle hard. If I ease up to full it sounds fine. I went to medium start from hard start and it got rid of the sound but the response may be suffering. So I have two questions...
1) is there a different setting I should change?
2) are there more options to pick on the timing with the programmer verses stick programming? the high timing on stick just says 22-30 but could I pick say 24 with the programmer?
link to the noise
Redwing RC Test run Extra 330 all Electric (0 min 18 sec)
marked the collet and it is not slipping
mchadwick63 is offline Find More Posts by mchadwick63
Old Aug 04, 2014, 09:34 PM
Joined Sep 2011
and could I benefit from a performance standpoint by programming the ESC with the computer link since I am running the A60 6XS?
Old Aug 05, 2014, 09:47 AM
I can fly anything..... Once!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
The USB Programmer allows you to choose a specific timing setting, rather than a range or "auto". This would be a good choice as it will allow you to "fix" the timing at one setting, such as 22 degrees.
It does offer more settings than the stick programming method, and also allows firmware updates.
Finally - if not already done, I highly recommend soldering the motor directly to the ESC - Bullet connectors and extra solder joints can cause this issue as well.
FL62 is online now Find More Posts by FL62
Old Aug 05, 2014, 01:24 PM
Joined Sep 2011
Have bullets now. I will try the direct solder. Thanks.
Old Aug 05, 2014, 10:45 PM
Joined Sep 2011
Something is not right. Tried high and low timing instead of automatic and the Squak can back even at medium start setting.
The Squak sometime actually acts like a break on the motor trying to stop it. It has only done it twice but it may help diagnose.
Also the other issue is I am only getting 6K rpm and pulling 60 amps. 370 KV on 6s is better than 8k rpm.
Sold Hacker A60-6xs V2 with ICE 100 ESC, and BEC Pro diggity2424 Aircraft - Electric - Power Systems (FS/W) 3 Mar 30, 2014 06:24 PM
Sold Hacker A60-6XS V2 & Phoenix Ice Lite 100 Ghog Aircraft - Electric - Power Systems (FS/W) 6 Mar 24, 2014 01:38 PM
Sold Hacker A60-6XS V2 Minimog Aircraft - Electric - Power Systems (FS/W) 2 Feb 04, 2014 02:15 PM
Sold Hacker A60-6XS v2 28 pole NIB graniteguy Aircraft - Electric - Power Systems (FS/W) 0 Jan 03, 2014 08:33 PM
Sold NIB Hacker X-110 Opto-Pro ESC $110 shipped / 48 Gabe_BigApple Aircraft - Electric - Power Systems (FS/W) 2 Oct 12, 2013 09:42 AM
