Old Mar 04, 2014, 11:52 AM
United States, NV, Henderson
Joined Sep 2013
Where To Buy Light Weight Loose High C Rated Lipo Cells
I am looking for a place to buy individual Lipo cells that are light weight, and have a decent C rating to build my own packs. I am thinking is 2s and 3s packs for my upcoming projects. 200ma 3S 30-45C 180ma 2-3S 30-45 C, maybe smaller, I wont know until I fish the build and test it.
Basically I want to order a big old box of tiny loose cells and build my own batteries. I see the packs a lot of the top guys use are custom made, where are you getting the good cells to build them with?
I hope this is not another one of those tightly held secrets, and you might consider to help me find what I need. Thanks for your time, AKf
akfreak is offline Find More Posts by akfreak
Old Mar 04, 2014, 12:34 PM
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
Thru All-E-RC you can buy Thunderpower individual cells. They were the best way to make small 2S and 3S packs until TP realized what people were doing and then made those packs available.
I think you'll find that the markup on packs is minimal, and not really worth your time making them yourself (well, that's what I found at least).
glenn2626 is online now Find More Posts by glenn2626
Latest blog entry: New Xtreme Video TX cable
Old Mar 11, 2014, 06:04 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Hyperion sells some of the smaller cells separately. (120/180/240/320)
http://www.aircraft-world.com/shopdi...Ah+and+Smaller
You can save about 1/2 a gram with the 120 cells versus a stripped down 2S 120 pack.
(Hyperion uses a small PCB to join the cells)
HK also sells individual cells. I have used the 240 and 360 cells in the past and they worked fine.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Discussion Spend weight on Capacity or C rating? Aviefly Batteries and Chargers 13 Oct 06, 2013 10:33 AM
Discussion Where to buy LIGHT weight floats .40-.60 size?? QuietRiot Waterplanes 12 Jun 30, 2010 07:47 PM
Help! Where to buy light weight, sub-micro servo leads? luger007 DIY Electronics 3 Dec 14, 2008 04:05 PM
Wanted i need 3 a low c rating high ma lipo cells burro breath Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 03, 2007 06:13 PM
Discussion Het F-18- Light weight Fixed Landing Gear, Where and waht to buy? jascamera Electric Ducted Fan Jet Talk 4 Feb 23, 2007 08:31 PM
