Old Feb 28, 2004, 06:01 PM
Sisyphus
Guest
n/a Posts
Sig SeaLane building tips and considerations
I a have just ordered a Sig Sealane, and will begin building shortly.
I will be installing an OS 40 LA (which was formerly pulling a LT-40
with authority), and I will install a Futaba 4 Channel with standard
servos.
I have never flown off of water before, and I have never built a
watertight craft before. I am seeking advice regarding the best type
of components to use, such as pinned vs. nylon hinges, and effective
construction and waterproofing techniques.
Also, anyone familiar with this particular craft may be able to
suggest a good prop size or type (9" or 10", 3 blades or two?). Any
tips on balance?
Thanks-
Sisyphus
Old Mar 01, 2004, 03:00 AM
strathboy
Guest
n/a Posts
Re: Sig SeaLane building tips and considerations
One tip when flying off water is to have sufficient power. The Sealane is
designed for a .40 size engine but an OS 40LA would not be my choice. You
need ample power to break the surface friction of the water and I would
strongly suggest a more powerful 46 size engine. In the air, float planes
also have more drag due to those appendages hanging from the wing and the
external power pod. Standard hinges are all that are required. The hull
should obviously be waterproof and this is best achieved by ensuring that
all joints are tight and sealed. during construction and that your finishing
method ensures no water gets into the wood or inside the hull. I prefer
several coats of finishing resin and then paint for the hull. Try to mount
your radio switch where it is least exposed to spray. A two bladed 10-6 to
11-6 prop is adequate for a 40 to 46 size engine. When you're ready, pick
the right day (morning) with just a tiny ripple on the water.
"Sisyphus" <sisyphusrises@yahoo.com> wrote in message
news:29d496cb.0402281437.1efe7d18@posting.google.c om...
> servos.
> tips on balance?
> Thanks-
> Sisyphus
Old Mar 02, 2004, 03:00 AM
Sisyphus
Guest
n/a Posts
"strathboy" <strathboy89@xpdoshus.com> wrote in message news:<104576nbs35l2a9@corp.supernews.com>...
That may be in the wings in the near future- as is a blackwidowav
camera setup- but for now, I must try to limp with a 40 LA. This
engine pulled my LT-40 nicely with a 9X6- my fingers are crossed. I
went ahead and ordered a 8x6 3 blader- but I think that I will pick up
a 10X6 per your suggestion.
> I prefer
Damn- I have already ordered monocote. Forgive my ignorance- what is
finishing resin? Does the paint need to be fuel proof? If so, what
paint is waterproof AND fuel proof?
Thanks for your advice- Barring death or hospitalization, this
project will go on the bench this week.
Thanks! ~Sisyphus
Old Mar 24, 2004, 06:06 PM
Joined Mar 2004
You can use MonoKote or any other covering material, UltraCote etc. Just be sure the seams over lap by at least 3/8 of an inche. It will water proof your Sealane. BTW, are you going to install the optional wheels for land flying or just fly off of water?
Mad Mad Max is offline Find More Posts by Mad Mad Max
Old Oct 03, 2008, 11:46 AM
Joined Oct 2008
monokote
> servos.
> tips on balance?
> Thanks-
> Sisyphus
but one question about this plane how do you put monokote on whithout it kinking.
williamws is offline Find More Posts by williamws
Discussion Sig Four Star 40 ARF Engine recommendations and Building Tips Daverp Beginner Training Area (Fuel) 24 Jul 12, 2009 02:38 PM
DAW Extra - Building Tips? Sal C Foamies (Kits) 27 Sep 26, 2001 09:08 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
Wattage F-22 Building Tips / Pictures rcfanatic Foamies (Kits) 9 Sep 08, 2001 02:25 PM
IFO Mark3: Any last minute building tips ? volt flyer Parkflyers 13 Jun 21, 2001 03:33 PM
