Old Oct 12, 2013, 08:44 PM
Promoting Model Aviation...
Murocflyer's Avatar
United States, CT, Litchfield
Joined Nov 2005
Suggested Motor for A Sig T-Clips
Need some help trying to pick out a motor and gearbox for my Sig T-Clips.
The recommended motor is an E-flite .32 or .40.
Our goal is to fly the airplane using a 4s 5000 mAH battery for 30 minutes at a time with maybe at least 10 minutes of spare flight time left on the battery.
We'll have a separate battery powering the servos and Rx so the main battery will only be powering the motor.
What motor and gear box would be best for that?
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Oct 12, 2013, 09:12 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Gearbox? Really?
Old Oct 12, 2013, 09:18 PM
Murocflyer's Avatar
Joined Nov 2005
Originally Posted by pda4you View Post
Gearbox? Really?
I think that may be the best way to go to get the most flight time out of the battery.
A geared setup seemed to work well for my indoor planes so it may just translate over in a larger scale.
Frank
Old Oct 12, 2013, 09:26 PM
pda4you's Avatar
Joined May 2002
I'm not sure you will get much more time if any using a gearbox. How big a prop can you spin?
Old Oct 13, 2013, 09:34 AM
Murocflyer's Avatar
Joined Nov 2005
I/m sure the T-Clips' landing gear height can support an 14" prop. I've seen mention of some folks using that size.
And I saw this note:
Originally Posted by Tom B 1956 View Post
The clearance for your choice of prop. You have about 8.5 to 9 in clearance from level from prop nut to the ground.
Tom B.
Frank
Old Oct 16, 2013, 04:33 PM
Murocflyer's Avatar
Joined Nov 2005
Finally got my rear gear on.
Frank
Old Oct 17, 2013, 12:57 PM
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
A 1907/2Y on your 4S battery would work well with a 10/8 or 10/9 prop---about 350 watts at full power.
A light weight geared option would be a 1107/2Y/6.7 with a 16/12 prop--about the same power level but better prop efficiency with the large prop.
The key item is to figure out the cruise power required......
Steve
sneu is offline Find More Posts by sneu
Old Oct 17, 2013, 05:35 PM
Murocflyer's Avatar
Joined Nov 2005
Thanks for the recommendations Steve!
How can I help answer your question? The key for this airplane is flight duration since the battery is the limiting factor. I suspect top speed requirements will be 55 mph since we'll be traveling back roads.
Does that help any?
Frank
Old Oct 22, 2013, 11:39 AM
sneu's Avatar
Joined Dec 1999
I usually go for the more exotic setups--my choice would be the 1107/2Y/6.7 with the big prop.
steve
Old Oct 23, 2013, 06:42 AM
Murocflyer's Avatar
Joined Nov 2005
steve
Copy that Steve and thanks for the the info. It doesn't look like we'll be able to use the Sig T-Clips, but I am sure this motor will be applicable to plane we finally decide on using.
Thanks again,
Frank
Old Oct 23, 2013, 09:13 AM
sneu's Avatar
Joined Dec 1999
The gear box on it's own is not going to give longer flights----but it can allow the use of much larger props with high pitch which can give much better prop efficiency---leading to more flight time and speed.
Steve
Old Oct 23, 2013, 09:14 AM
sneu's Avatar
Joined Dec 1999
Thanks again,
Frank
Why not?
Steve
Old Oct 23, 2013, 09:19 PM
Murocflyer's Avatar
Joined Nov 2005
Why not?
Steve
The fuselage compartment is not big enough to hold the Rx battery and the Scorpion backup battery. The fuselage is very short, and does not allow much room for things like that. I didn't realize this until I bought one for myself to do the testing with. It does have a cool slide in battery tray design, but without cutting the covering and building a tray underneath the servo tray, those two batteries will not fit. I know it wouldn't be hard to do, but I'd prefer to find a plane we could use that would be stock, right off the shelf.
If we did use the T-Clips and modified it, there will be folks that would say we couldn't have done this without modifying the airplane. I need to see what else Sig has to offer in the ~ 5 lb range that will work for us.
Frank
Old Oct 26, 2013, 10:23 AM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
This hobby is about making things work and the learning experience that goes along with it. Nobody frowned on Maynard Hill when he flew across the Atlantic because it wasn't ARF. Anyone with enough effort could duplicate his efforts.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Oct 31, 2013, 07:55 AM
pda4you's Avatar
Joined May 2002
The fuselage compartment is not big enough to hold the Rx battery and the Scorpion backup battery. The fuselage is very short, and does not allow much room for things like that. I didn't realize this until I bought one for myself to do the testing with. Frank
Frank this is what you want....
http://www.horizonhobby.com/products...basic-EFL10450
The Carbon Cub from Horizon....
Here is why:
  • Large easy to see
  • Easy to fly
  • Flaps for slow down
  • Large tires for those less than desirable landing zones
  • Super easy to repair
  • Rugged
  • Room for 6s 5000 pack should easily get you the time needed
I think it would be awesome....for this purpose.
Discussion Sig's New T-Clips pdansalvish Electric Plane Talk 393 Aug 02, 2014 05:14 PM
Discussion Sig T-Clips Frank Hurd Sport Planes 15 May 18, 2014 11:48 AM
Discussion Motor Suggestions for Sig Senior keninaz Power Systems 5 Aug 25, 2013 09:16 AM
Discussion Sig T-Clips Frank Hurd Sport Planes 0 Jun 26, 2013 09:37 AM
