Old Sep 14, 2013, 08:22 AM
Joined Nov 2007
converting Sig Spacewalker II to Electric
Has anyone made this conversion? What was the modification made for battery placement? What size electric did you use? Do you have any pictures of the conversion and battery placement?
americanflyer is offline Find More Posts by americanflyer
Old Sep 14, 2013, 01:49 PM
FICKLE FLYER
tlh101's Avatar
Corpus Christi, Texas, United States
Joined Dec 2002
I converted a foam and glass copy of the SIG Spacewalker II several montha gao. My best flyer to date. Here's a link to my build: http://www.rcgroups.com/forums/showthread.php?t=1750845
tlh101 is offline Find More Posts by tlh101
Old Sep 14, 2013, 02:48 PM
Joined Nov 2007
Thanks for your reply. Who makes the plane you converted to electric? I'm concerned that the built up model by Sig will be a challenge for battery placement. I like the way you handled this in your build.
Old Sep 14, 2013, 03:16 PM
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
I don't remember the name of the company. Was a 1 man band and only did a few kits quite a while back.
Old Sep 18, 2013, 04:54 PM
USA, FL, Hudson
Joined Dec 2009
I'm in the middle of completing a partial build I recently picked up. I plan to power it with a Tacon 160 and a pair of 5s 5000. I am using the same setup on my H9 Taylorcraft and it has plenty of power. I have a few pics of my progress so far if I get them to work.
Description:
Description:
Troy S is offline Find More Posts by Troy S
Old Sep 20, 2013, 09:38 PM
Joined Nov 2007
Attachment 6113725
Attachment 6113726
Looks real nice. How are you handling the battery placement?
Old Sep 21, 2013, 11:04 PM
USA, FL, Hudson
Joined Dec 2009
Two 5s 5000 batteries fit side by side on the angled tray with just enough clearance for the hatch, the life pack I use for the receiver sits in the small arched top section in front of the hatch. I haven't tried to balance anything yet, but that's as far forward as you can go without putting the batteries in the cowl.
Old Sep 23, 2013, 07:45 AM
Joined Nov 2007
I have a great planes stearman older kit weighs in around 18 lbs and I powered it withe the Tacon 160 and 2 5000 5s batteries. Had to use a HV esc and seperate bec, plane has plenty of power. Could the batteries on the spacewalker fit on a tray going into the forward cockpit with some modification? Thanks a lot with your help on this
Old Sep 24, 2013, 05:11 PM
USA, FL, Hudson
Joined Dec 2009
The floor in the cockpit runs all the way to the firewall. From the cockpit area you could build a lower forward tray to slide them in on.
Discussion SIG Spacewalker II motor suggestions Troy S Glow to Electric Conversions 3 Aug 24, 2013 07:27 PM
Sold Sig 1/4 scale Spacewalker II Kit $160 shipped rightname Aircraft - Fuel - Airplanes (FS/W) 2 Aug 03, 2013 09:16 PM
Sold Sig Spacewalker II and NIB OS Gemini 160 LPU KaP2011 Aircraft - Fuel - Airplanes (FS/W) 2 May 21, 2013 07:18 PM
Sold 1/4 Scale Sig Spacewalker II Kit NIB $155.00 FREE SHIPPED!!! stevster Aircraft - Fuel - Airplanes (FS/W) 3 Mar 11, 2013 12:48 AM
Yippee! 1/4 scale SIG SPACEWALKER II M_Schneider Aircraft - Fuel - Airplanes (FS/W) 1 Nov 06, 2003 11:58 PM
