Old Oct 02, 2012, 05:53 PM
Rcflyyer1's Avatar
United States, FL, Sarasota
Joined Dec 2010
Cylinder Sleeve STUCK!!
Ok so I am now desperate! This liner has just been fighting me from the start. So the engine is an O.S. 46FX that was given to me to change the bearings in and man this thing has been a real son of a . The engine has been used a lot since it has carbon build up inside. So what I have done is cooked it in the oven at 310 degrees F and have actually gotten the liner to pop up. On the FX engines, the liner doesn't sit above the crankcase, when you take the cylinder head off, the liner is flush with the top of the crankcase. So anyways I did the exhaust port trick and it worked and pooped the liner up a little but it wasn't enough so I hammered it from below with a dowel. I have gotten it up about 8mm and now it's stuck for good it seems. I cannot hammer it with the dowel from the bottom anymore since the piston and the bottom of the liner are now equal when you look up the bottom of the crank case. I have even put it in the freezer and then submerging it in warm water and that doesn't work. I do not want to use pliers since that ruins the liner of course. I cannot use my fingers to pull out the liner from the top and am now out of ideas. My fingers are now all red and burned by the paper towels I was using. Please if you have any ideas please please please please please tell me! Thank you.
Rcflyyer1 is offline Find More Posts by Rcflyyer1
Old Oct 02, 2012, 06:05 PM
Joined Jun 2011
Put a copper plug washer in the exhaust on top of thepiston just enough to catch on the crankcase and turn the engine over. The washer will push the liner out.
datsunguy is offline Find More Posts by datsunguy
Old Oct 02, 2012, 06:14 PM
Mach 1
pathfinder's Avatar
walterboro s.c.u.s.a
Joined Jun 2004
Get butane torch from Walmart and heat the case .I t will come out that way.Heat is your best friend when working with these engines.
pathfinder is offline Find More Posts by pathfinder
Latest blog entry: Nice
Old Oct 02, 2012, 06:33 PM
United States, CO, Arvada
Joined Sep 2007
Aluminum cannot tolerate heat near or above 320 degrees!!!! It will change the molecular structure. Questions? Contact Paul at RC-Bearings (owner).
SeamusG is offline Find More Posts by SeamusG
Old Oct 02, 2012, 07:31 PM
Rcflyyer1's Avatar
Joined Dec 2010
I have used almost everything including a torch, heat gun, and desperately a hair dryer with no success.. Do you have any more ideas?
Old Oct 02, 2012, 08:41 PM
Joined Sep 2007
How about a penetrating chemical like PB Blaster. It's safe for both steel and aluminum. Might just cut thru the build up.
Old Oct 02, 2012, 08:48 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
If you try the copper washer trick, make sure you have everything ready to go. Heat the case quickly and see if the sleeve will move. DO NOT dilly dally around trying to get the washer in AFTER you heat the case. The idea is to get the case as hot as possible without warming the sleeve. Put the case in a vice of some other holding fixture like a breakin stand. That way you have one hand for the torch and the other to turn the crank via the prop or what ever.
I hope you succeed!!
ken
EDIT; You may want to push the sleeve back in the case first, at the least half of what you have out now. In fact if it were me I would do that. Good Luck!!
kenh3497 is online now Find More Posts by kenh3497
Old Oct 02, 2012, 09:31 PM
Airplane Gearhead
Central N.Y.
Joined Jan 2005
It sounds like you probably have some of that Carbon from around the Exh. port, wedged in between the case and sleeve. If you can get the sleeve back down, and clean as much crud out of there as you can, it might help. Q-tips can usually get most of it, along w/ automotive carb cleaner.
PB Blaster works well...and heat...and lots of patience...and you will probably need to try it several times before you get it.
When the PB Blaster begins to smoke (when heating the case) you know you are getting it hot enough.
proptop is offline Find More Posts by proptop
Old Oct 02, 2012, 09:38 PM
Rcflyyer1's Avatar
Joined Dec 2010
Cool I will have to go buy some. I did spray WD-40 between the liner and the crankcase. Is WD-40 a penetrating oil? Thanks
Old Oct 02, 2012, 11:08 PM
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
WD in my opinion is not the best, something like Liquid Wrench is much better.
jeffie8696 is offline Find More Posts by jeffie8696
Old Oct 02, 2012, 11:28 PM
Cox Engine Hoarder
Jason_WI's Avatar
Neenah, Wisconsin, United States
Joined Jun 2004
On one engine I had to heat the case with a small torch till it just started to smoke and then hit the sleeve with a shot of freeze spray to super cool it on the inside. after cooling it it almost fell right out. Now you have to be careful not to get any of the liquid freeze spray on the crankcase aluminum as you may crack it from the temp extreme. I used a paper towel stuffed on the bottom of the crankcase to prevent the liquid from touching the aluminum. If you can't find freeze spray at an electronic parts store then you can use the canned air upside down to get liquid out.
Jason
Jason_WI is online now Find More Posts by Jason_WI
Old Oct 03, 2012, 10:09 AM
Joined Sep 2007
Many local car shops keep PB on hand for tuff "tight" situations. I'm currently working on separating a turbine case from the bearing case of my Garrett turbo. The compressor case is aluminum. The other two are steel. PB Blaster needs up to a couple of days to work into the seams after a couple of a hundred thousand miles. I'd give PB a try and demonstrate patience.
Old Oct 03, 2012, 12:44 PM
Reginald's Avatar
Belgium
Joined Aug 2004
The engine has piston rings ? I've had the issue in the past that when the cylinder or piston were turned around, the ring(s) may get stuck in the ports.
Be carefull with too high temperatures when heating up. The suggestion of using those freeze cans (always have them handy around) may work, that is how I replace bearings in the castings, freeze up the bearing and warm up the cating. Always works. When both metals are joined it becomes more difficult.
Reginald is offline Find More Posts by Reginald
Old Oct 03, 2012, 01:53 PM
Rcflyyer1's Avatar
Joined Dec 2010
No this is an ABL engine so there is no ring in mine.
Old Oct 06, 2012, 12:55 AM
Transplant in 1996
United States, NE, Scribner
Joined Aug 2011
Lots of info so far, but the only way to get it out is a day or 2 in a antifreeze(green) in a old crockpot. I do it all the time. At present 198 engines out of 201 worked great!!!!
Transplant92 is offline Find More Posts by Transplant92
Wanted YS 91 AC Cylinder sleeve androsmj Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 09, 2007 10:26 PM
cylinder sleeve MoD_Eagle Engines 5 Dec 12, 2005 10:38 AM
HELP--Sleeve is Stuck! sgillmore Engines 8 Apr 20, 2005 02:56 PM
