Old Mar 25, 2012, 09:00 PM
The Sweet Aroma of 92 Octane
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
ember 2 electronics?
hey guys. is it possible to build a micro cessna 210 by using the electronics out of an ember 2?
electricrc68 is online now Find More Posts by electricrc68
Old Mar 25, 2012, 10:05 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Yes. You need to trim about .200" of foam because the brick is larger and swap in a J-3 (plug in) motor and the 210 is DSM2. Otherwise it is 100% swap in and fly.
The J-3 gearbox should be used, too, because the Kyosho gearboxes are a little wobbly.
UNGN is offline Find More Posts by UNGN
Old Mar 26, 2012, 03:48 PM
Joined May 2011
okay thank you! looks like i may be converting my ember to a 210 soon then.
Old Mar 26, 2012, 03:56 PM
Joined May 2011
Okay so now i got my list of parts made up. is this all i would need?
Propeller....Unless the Ember Prop works?
Nose Gear
Decals
Main Gear
Tail Wing Set
Motor
Gearbox + Shaft...or is that the wrong shaft?
Pushrod Accesories...unless the ones from my ember will work?
Sold Parkzone TX, charger and Ember 2 Rec Brick carosielli Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Feb 13, 2012 04:45 PM
Sold Micro Mustang kit with new motor, and used green dot Ember 2 brick phoneguy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Apr 11, 2009 04:15 PM
Wanted looking for vapor,ember 2 or dsm2 brick LexusIS300 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Apr 03, 2009 03:37 AM
Found Ember or Ember 2 Airframe without brick. Twmaster Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Feb 16, 2009 06:29 PM
Sold Parkzone Ember brick, lipos, (2)motors, connectors, and TX $70 shipped mrfliboy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 25, 2008 11:34 AM
