Old Feb 14, 2004, 04:22 PM
I'm Me Again!
Jerry Rose's Avatar
Joined Feb 2002
Originally posted by kaja
... my indoor bird flies now.
Congratulations!
Jerry Rose is offline Find More Posts by Jerry Rose
Old Feb 14, 2004, 07:37 PM
Joined Sep 2003
Kaja,
Congratulations. Excellent design and craftmanship.
Question: I have not found specifications for the Faulhaber 1524T motor that you used. Do you have a link to them?. If not ,and you have a spec sheet, would you share the following specs:
Rated Voltage
Short circuit current or ohms
No load current
Max no load rpm or Rpm/volt
Thanks, and many good flights!
GB
Plantoflap is offline Find More Posts by Plantoflap
Old Feb 15, 2004, 02:21 AM
munich/germany
Joined Apr 2003
Motor Faulhaber 1524T 003SR has:
3V rated voltage
1,13Ohm , 47mA no load current, 3660rpm/V
All data you can find in www.faulhaber.de ->produkte->produkte->motoren->DC-kleinstmotor->1524 SR
Karel
kaja is offline Find More Posts by kaja
Old Feb 15, 2004, 04:11 AM
FrancisG's Avatar
Dijon. France
Joined Nov 2002
Super, Karel !
Francis
FrancisG is offline Find More Posts by FrancisG
Old Feb 15, 2004, 01:27 PM
munich/germany
Joined Apr 2003
Hi,
hier is 1. video with my indoor bird, 1MB/15sec. I have replaced old video with new one, i have no place on my HP.
http://pustka.bei.t-online.de/Flattern.avi
Some pictures are in http://pustka.bei.t-online.de/Flapper.htm
Karel
Old Feb 15, 2004, 06:25 PM
Seale, AL
Joined Oct 2003
wmueller10 is offline Find More Posts by wmueller10
Old Feb 16, 2004, 02:11 AM
munich/germany
Joined Apr 2003
Your suggestion will sure works. But there is still problem with active twisting. In this glide position is the wing too much twisted and i can do nothing against.
Karel
Old Feb 16, 2004, 05:37 AM
Seale, AL
Joined Oct 2003
Old Mar 18, 2004, 03:20 AM
munich/germany
Joined Apr 2003
Here my first styro wing with my step twist princip. It works without problems and glides best of all my wings till now. Now i will test several profiles . It is very easy because we have in my club CNC-maschine to cut it automaticaly.
Regards Karel
Old Mar 18, 2004, 09:48 AM
I'm Me Again!
Jerry Rose's Avatar
Joined Feb 2002
That bird looks great! Excellent work!
Old Apr 05, 2004, 12:11 PM
munich/germany
Joined Apr 2003
Some pictures from show during contest F3AI - Bavarian Open 2004 in Poing you will find in page 4,5,14,15 in
http://www.fmpoing.de/index.php?id=1...=false&navi_se ,see Bilder & Bavarian . In Germany is a ornithopter very rare.
regards karel
Old May 02, 2004, 08:05 AM
munich/germany
Joined Apr 2003
I have changed to normal tail because i will stabilised elevator with gyro, see http://www.acteurope.de/html/pico_smm.html It steers better and flies stabler.
Old May 08, 2004, 08:05 AM
KOROBELNIK's Avatar
PARIS
Joined Oct 2002
So unstable?
Karel,
why Gyro?
Your oprnithopter is so unstable?
Regards & Grusse
Robert
KOROBELNIK is offline Find More Posts by KOROBELNIK
Old May 08, 2004, 02:37 PM
munich/germany
Joined Apr 2003
Yes Robert. It is not enought stable because CG must be aft for flapping with good climbing and that is bad for good stability in gliding. My styro wing glides very good now but i must steer much or glide only in circles.
Salut Karel
Old Sep 06, 2004, 04:52 PM
KOROBELNIK's Avatar
PARIS
Joined Oct 2002
I have just learnt that Karel left us on June 28 for a better world.
I am very afflicted of the disappearance.
Goodbye Karel
Condolences in Your family.
R.Korobelnik
Video P-51D, Maiden Flight Of A Self Made Mustang Jan-Henrik Electric Plane Talk 7 Oct 14, 2009 03:55 AM
self made carbon folding prop eitanro Electric Sailplanes 7 May 01, 2005 07:19 PM
Self Made In door with problem Cooler_V Scratchbuilt Indoor and Micro Models 1 Sep 13, 2004 09:58 AM
Self-made ballast tube Kai@UCSB Slope 7 Feb 29, 2004 08:24 PM
60 m.p.h. BluCor Delta.. Ultimate? Razorback Foamies (Kits) 33 May 13, 2003 10:44 AM
