Old Feb 15, 2013, 10:42 PM
United States, ID, Burley
Joined Mar 2012
Help!
three channel control
Okay a buddy built a 3 channel power glider all balsa, rudder,throttle,elevator. He has put rudder on the right side with elevator,so the question is this. When turning with rudder only how do you keep wings level so it doesn't tip to one side ??
fastfwd is offline Find More Posts by fastfwd
Old Feb 15, 2013, 11:38 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
You don't. Tipping to one side is rolling, just like with ailerons. It's what actually turns the plane; the rudder induces a yaw motion which is translated to a roll by the wing's dihedral.
If the plane is tipping AWAY from the direction of the turn, however, then the plane needs a bit of rethinking - or ailerons.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Feb 15, 2013, 11:53 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
With no ailerons, if the wing has any amount of dihedral you can't. The airplane will always roll in the direction of rudder input. But that is exactly what you want it to do. A banked turn is a lot more efficient than a flat, wings level turn. With a banked turn the airplane will lose a lot less energy.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Feb 16, 2013, 03:00 AM
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
And... when you turn on rudder, the dihedral allows the model to bank a little (helping the turn) but the inside wing on the turn will be near enough flat and providing lift where a non-dihedral wing would be spilling the air from under it, thus requiring elevator to make the banked model turn. Steering is always on the right stick (mode2) so 3ch it's the rudder, 4ch it's ailerons. The rudder becomes secondary on a 4ch model, used more for scale turns or aerobatics
RWData is offline Find More Posts by RWData
Old Feb 16, 2013, 01:24 PM
Joined Mar 2012
thanks gents ! Makes sense we will fly the maiden as soon as wind dies down.
New Product Air Hogs Dive Master 3" 3 Channel Remote Control Submarine NEW w/ Ballast Tank Ricomon Submarines 145 Jun 18, 2014 09:44 AM
4-Channel Electric UAV RQ-1 63" Radio Remote Controlled RC Spy Plane ARF Mr_Delavar Non R/C Items (FS/W) 0 Feb 01, 2013 03:31 AM
Help! S107G Alloy & Plastic 3D Full-Scale Three-Channel Gyroscope RC Helicopter with Light rameshv Batteries and Chargers 0 Jan 15, 2013 10:21 PM
Sold Three 41cc Gas Engines for sale at one price !!! $150 takes all three ! shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 04, 2013 05:34 PM
Sold Futaba 7C 2.4 radio, Three 7 channel receivers, and One 6 channel Receiver SSYeats Aircraft - General - Radio Equipment (FS/W) 5 Oct 06, 2011 01:31 PM
