Old Dec 29, 2012, 08:20 AM
Joined May 2012
New
So i received this engine for Christmas.
http://www.horizonhobby.com/products...engine-ZENEP62
I am looking for a plane, I have been looking and I found these 2 that I really like.
http://www.arfpros.com/ESM-DHC-2-Bea...AVER-95AAF.htm
http://www.sdshobby.net/new-pitts-s1...c#.UN771uTAd8E
I have been flying for about 2 years. At this point I have flown all top wing aircraft. I have 2 glow planes, a cub and a Cessna. My question is would the biplane be too much of a jump? I have always wanted a biplane, so that is my first choice.
dearjhn is offline Find More Posts by dearjhn
Old Dec 29, 2012, 08:46 AM
kimchiyuk's Avatar
United States, NY, Eldred
Joined Jun 2012
Without knowing your actual flying skill level, it would be hard to say. Bipes can be an animal all their own. Especially since you're looking at the pitts. It has a short tail moment and can be quite snappy. More of an Aerobatic plane than a sport flyer. Also, many bipes need to be flown all the way to the ground on landing, not like a cub that floats and practically lands itself. Also, bipes have no self correcting tendencies like that of a high wing with dihedral. Not trying to discourage you, just giving a heads up and some pointers. I personally started flying an ultimate with no problems after 200 flights with trainers and low wingers. Good luck with your choice... bipes are awesome!!!
kimchiyuk is offline Find More Posts by kimchiyuk
Old Dec 29, 2012, 09:20 AM
Joined May 2012
Thank you for your honesty. My first plane was a corsair that a local hobby store told me would be a great beginner plane, well that didn't end very well. Well maybe I should get a low winger, I have time to figure it out.
Old Dec 29, 2012, 09:25 AM
texas
Joined Jul 2009
I myself really like the beaver I have always like that type of plane.I just got my first bi-plane for Christmas And i'm being told that they will wing tip vary easy.[I] guess we will both find out.GOOD LUCK.
luker737 is offline Find More Posts by luker737
Old Dec 29, 2012, 10:44 AM
Jacksonville Fla.
Joined Mar 2007
I have flown a Pitts Python for a while....if your new to bipes then you better learn throttle control quickly as a bipe will stall on you in a heart beat....I am kinda amamzed at the 2 completely different aircraft you have chosen...the beaver will be more docile then the pitts and alot less manuverable. There are other aircraft out there try Chief aircraft and look at all the 50CC they have...
I guess it comes down to how you fly...which aircraft to get.....Bipes get alot of attention...I have flown the Pitts Python and the Goldberg Ultimate....I like faster do any manuver airplanes.
Now don't worry to much about flying a bipe....any bigger aircraft is going to take throttle control...get with some of the gas flyers you are around ask them for advice...Good Luck
jetmech05 is offline Find More Posts by jetmech05
Old Dec 29, 2012, 10:52 AM
Unregistered User
Kerwin49's Avatar
United States, MO, Winston
Joined Jan 2011
+ 1 on the Beaver.
Give yourself a bit more stick time before jumping to a Pitts.
Kerwin49 is offline Find More Posts by Kerwin49
Old Dec 29, 2012, 11:18 AM
Joined May 2012
Jet: I guess the reason for the 2 different types is because I kind of don't want to jump into something and turn my plane into splinters. These 2 would be my choices.
Kerwin: I am leaning towards that myself.
Old Dec 30, 2012, 07:11 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
My vote is for the Beaver also. The G-62 is a great motor too! It was my first gasser when i got started. You'll love it.........Gene
gene6029 is online now Find More Posts by gene6029
Old Dec 30, 2012, 08:29 AM
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
The Beaver is the safe choice. Will fly similar to you have flown. If your bored with hose flyers and looking for some more fun. The Bipe would be a big jump but if you have high rates and low rates. Put your low rates very low. You should be fine. Just remember to come in with a little power. About 10-15% above idle and cut it just as you get ready to touch. It would make it easier if you know an Advanced Flyer at your field to help you. Maybe fly it and get er trimmed. I'm transitioning a friend of mine from trainers to full Aerobatic flight.
It's a handful if your initial flight is on high rates. Low low rates and its easy.
Dale 813 is offline Find More Posts by Dale 813
Old Dec 30, 2012, 03:21 PM
Joined May 2012
Thanks Dale, finding someone to help should not be a problem, I do have high rates and low rates. I will just have to make a decision and go with it. I also may buy a foam biplane first. I have time, I just finished a cub with a .45 enya and have started a Cessna with a .65ASP, I am having fun with them for sure.
For Sale Headplay FPV Goggles!!! New new new!!! Great resolution!!!' Ecibob FPV Equipment (FS/W) 1 Mar 20, 2013 12:03 PM
New Product NEW NEW NEW Flight Design Freewing 1200mm Wing Span Trainer www.hobbyb.com Foamies (Kits) 12 Feb 22, 2013 10:17 AM
Sold DX7 $125 shipped, Near new W New neck strap, Hanger, NEW battery too THX-181 Aircraft - General - Radio Equipment (FS/W) 2 Sep 11, 2012 03:42 PM
Sold Castle Creations HV ESC's: Ice2 60HV (new), Ice2 80HV (new), 85HV (used), 110HV (new) jgalexander Aircraft - Electric - Power Systems (FS/W) 11 Apr 26, 2012 07:26 AM
Discussion Quad New New New Newbie STLCOP Multirotor Talk 18 Feb 29, 2012 12:05 AM
