Old Sep 04, 2009, 10:50 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Question
30mm Spinner for 5mm shaft?
As the title says, is anyone aware of a 30mm spinner that fits a 5mm motor shaft? I feel like i've searched high and low, but can't find anything, and I thought maybe someone else had an idea...
I've got a 1115 with a 5mm shaft begging to go fast...
Edit: I should note that im looking for a non-folding prop spinner, but if it was possible to modify a folding spinner, id be happy to be enlightened
Thekid3418 is offline Find More Posts by Thekid3418
Old Sep 04, 2009, 07:55 PM
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Not really spinners but the only 5mm I could find. Maybe you make something work.
http://www.hobbycity.com/hobbycity/s...78__5mm_to_8mm
http://www.hobbycity.com/hobbycity/s...mm_motor_shaft
r/cmark is offline Find More Posts by r/cmark
Latest blog entry: FrSky Taranis misc stuff
Old Sep 05, 2009, 12:42 AM
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
That's like trying to shoehorn a small block chevy into a VW Bug.
I am not aware of any 30mm spinners that will take a 5mm shaft.
fly_boy99 is offline Find More Posts by fly_boy99
Old Sep 05, 2009, 03:09 AM
Brussels, Belgium
Joined Nov 2000
Aeronaut part number 7259/05, ooops, i didn't read all the original post, this one is for folding props, and I don't see how to modify it...
Maybe have a look at this: http://spinners.tealbox.com/ I'm almost sure it is possible to change the 4mm version in a 5mm.
Sebastien is offline Find More Posts by Sebastien
Old Sep 05, 2009, 04:12 AM
Silicon Valley, CA
Joined Jun 2008
Sorry, the BB Turbo is for folding props only, I missed the fact you wanted a fixed prop spinner the first time through.
sundog4 is offline Find More Posts by sundog4
Old Sep 05, 2009, 05:55 AM
Darron's Avatar
London
Joined Jul 2003
They can be modified for a small fee or you can do it yourself.
Darron is offline Find More Posts by Darron
Old Sep 05, 2009, 08:53 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I've assembled such a setup from spare colletts and parts. You need a cap that uses a center screw for retention, a collett that has a threaded hole up front for said screw, but a small enough shaft for your prop, and a back-plate that works with the collett you choose. Can't provide any specific parts, just know it's possible to pull it together from various parts..
..a
Old Sep 05, 2009, 10:33 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Thanks for this link. I sent them an E-mail to see if they could make a special one. Although I think it might be possible to bore out my own, i'd rather not take that risk.
Andy, thanks for that tip. From what i've had (5mm collets and 3.175 spinners) I can't really wrap my mind around what you can do. The problem is most of the spinners take the smalll apc adapters (~5mm?), and the 5mm collets always take an 8mm bore. Maybe I need to look around a little more, as your idea sounds great since you don't have to modify anything...
Thanks all again
PS, Flyboy: Hows a 7x10 at 17k rpm and 700 watts sound
Old Sep 05, 2009, 03:39 PM
Calgary, AB, Canada
Joined Oct 2002
Used to be graupner 30mm spinners were only available with 3.2mm shaft + 8mm prop hole, but according to this, they have one for 4mm shaft.
http://www.hobby-lobby.com/30mm_prec...QueryId=177553
The question is, is there enough meat left in this model's hub area to bore to 5mm as a retrofit? Maybe they can provide you dimensions. If so, I'd recommend boring it out in a lathe with a collet so the new hole is true. Off-center & out of balance even a little bit, is a bad thing at high rpm.
ptxman is offline Find More Posts by ptxman
Old Sep 05, 2009, 06:10 PM
Darron's Avatar
London
Joined Jul 2003
As you can see in this picture there is a boss sticking out the back of the spinner where they have the 4mm bore. The prop shaft is still 6mm so the bore does not go as far as that as it would be too weak. Therefore if the boss is not a problem, boring out to 5mm should not be a problem, although not the best solution IMHO.
Old Sep 05, 2009, 06:40 PM
Battery Puffer
Orange, California, United States
Joined Nov 2001
I think it would be easier to just get a new rotor from Steve.
Mark
MarkF is offline Find More Posts by MarkF
Old Sep 05, 2009, 06:47 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
This is a good point. It certainly is the most fool-proof idea...
I like the stability of the 5mm shaft, as this motor sees duty in slightly more abusive applications (stryker, etc). So i'd like to maintain the strong shaft if possible...
Old Sep 06, 2009, 08:00 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
.. OK, I remembered what I did. I used the cheap DuBro (or similar) plastic spinner, and adapter it (judicious application of dremel sanding wheel) so that it could be used with a regular 5mm adapter. I have picked up a dozen or more different sized spinners at swap meets over the years, and had one or two that worked..
..a
Old Sep 06, 2009, 10:53 AM
jattamasso's Avatar
Coimbra, PT
Joined Dec 2005
Try Reisenauer.
info@reisenauer.de
They have 30mm and 5mm shaft. Very good spinners. Impossible to come loose.
jattamasso is offline Find More Posts by jattamasso
Old Sep 06, 2009, 01:55 PM
Dallas, TX
Joined Jan 2005
I had to modify a Turbo spinner for my Neu 1110 with a P32 gearbox that has a 6mm shaft. I drilled the collet out to 6mm where it fit very tight. That was a 40mm spinner so I would think a 30mm with a 5mm shaft would be even harder to find. Although I had a thought while writing this and went to:
http://www.aircraft-world.com/shopexd.asp?id=4079
Might work?
Alan
jh2rc97 is offline Find More Posts by jh2rc97
Discussion 30mm folding spinner for 3mm shaft ggouveia Electric Sailplanes 6 Sep 03, 2007 09:04 AM
Wanted 2" spinner for 5mm shaft, 11 x 8.5E APC prop Megowcoupe Aircraft - Electric - Power Systems (FS/W) 0 May 13, 2007 01:17 PM
Sold 30mm Precision Aluminum Spinner for 3mm shaft 3Deranged Aircraft - General - Miscellaneous (FS/W) 1 Sep 20, 2006 03:15 PM
Found 30mm folding spinner for 5mm shaft/8mm root jjs63james Aircraft - Electric - Airplanes (FS/W) 8 Oct 10, 2005 09:15 PM
wtb: 30mm spinner for 5mm shaft, (folder) 8mm pin opualuan Aircraft - Electric - Airplanes (FS/W) 1 Jan 03, 2003 12:28 PM
