Old Apr 30, 2014, 12:54 PM
United States, CA, Roseville
Joined Apr 2014
X1 MF or EZ Peak Plus Need help deciding on charger...
I'm trying to decide on which charger to get. I want something fairly cheap so less than $80. Both of these chargers are right at that price point. Right now I only have 1 3S 2200mah LiPo battery, but later on I will eventually get a 6S for a plane.
Any recommendations between the 2? Or anything better these around the same price or less?
FlyinSolo is offline Find More Posts by FlyinSolo
Old Apr 30, 2014, 01:18 PM
United States, MN
Joined Feb 2011
If you will be getting into 6s later both chargers are woefully inadequate.
Give these articles a read to find out why:
http://www.tjinguytech.com/charging-...e-for-charging
http://www.tjinguytech.com/charging-how-tos/shopping
Also give some thought to if you will want to do parallel charging eventually.
grimbeaver is offline Find More Posts by grimbeaver
Old Apr 30, 2014, 02:43 PM
Joined Apr 2014
Good read! Thanks!
Would you stay away from HobbyKing Chargers? They have this one https://www.hobbyking.com/hobbyking/...e_Charger.html ?
Old Apr 30, 2014, 05:05 PM
United States, MN
Joined Feb 2011
The most recommend chargers are iCharger and Revolectrix (aka FMA Direct). Both are very high quality. Also both can be bought from US vendors rather then doing expensive international shipping from HobbyKing. The two most common vendors are ProgressiveRC and BuddyRC.
If you want an inexpensive small starter charger for now, which you will still find uses for later, then the Accucel-6 is good:
https://www.hobbyking.com/hobbyking/...arehouse_.html
And if you need something to power it one of these:
Both items are in the USA warehouse so shipping should not be too bad.
Old Apr 30, 2014, 05:14 PM
Joined Dec 2003
Originally Posted by FlyinSolo View Post
Good read! Thanks!
Some people would argue that staying away from Hobby King entirely is a good thing.
Hobby King does not stock that charger in their USA warehouse so you would be paying for shipping from China. You can get the same charger from a USA based vendor (free two day shipping to Roseville) for about the same total price as from HK.
I'm not endorsing that particular charger. I have no personal experience with it. If you end up staying with the hobby long term then investing now in a capable charger will pay off fairly quickly. Buy cheap, buy twice.
aerobear is offline Find More Posts by aerobear
Old May 01, 2014, 07:00 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Rather than the iCharger 1010b (10S at 10 amps) I would be looking at the iCharger 206B (6S at 20 amps) at about the same price. I doubt that you will need a 10S charger.
If you can possibly conceive of needing to charge more than one or two 6S batteries then I would consider the FMA PowerLab6 (PL6, 6S at 40 amps).
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
For Sale Traxxas EZ Peak Plus 6amp Charger jkirsch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 15, 2014 09:28 PM
Discussion Need help with Hitec X1 MF harryb49 Batteries and Chargers 4 Dec 31, 2013 01:28 AM
Discussion Need help deciding plane to start out on. monkeyhacker FPV Aircraft 37 Dec 09, 2013 07:54 PM
Discussion Blade 130x or 450x, need help deciding mguido6 3D Electric Heli Flying 7 Nov 16, 2013 05:04 PM
Sold Traxxas ez peak charger nightfiref7efi Aircraft - Electric - Batteries & Chargers (FS/W) 1 Oct 12, 2013 03:49 PM
