Old Apr 04, 2013, 04:13 PM
USA, AZ, Tucson
Joined Aug 2008
Type of Kevlar to use to hold magnets in place
I am working on an inrunner that has a 4.5" OD by 2.25" stack length rotor. I am trying to find the correct Kevlar thread/yard/tape to use to wrap the rotor in to hold the magnets in place. I know I need an uncoated product for my high temperature epoxy to adhere to. I would just wondering what brand/source do you use.
David
leybold12 is offline Find More Posts by leybold12
Old Apr 06, 2013, 05:00 AM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
I have kevlar roving, its easy to pull out a strand and wrap it around something and soak with thin CA..
on the up side if there is clearance you can wrap with spider wire kevlar fishing line
Carbon tow will withstand heat way better, kevlar will melt with a match....
ApexAero is online now Find More Posts by ApexAero
Old Apr 06, 2013, 08:01 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
If the motor is getting that hot, you got bigger problems than melted Kevlar
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Apr 08, 2013, 12:32 AM
Australia, VIC, Melbourne
Joined Feb 2010
Indeed, like the fact your magnets are not magnetic any-more (in fact they are likely liquid) as are the windings and anything AL (even steel will be getting rather soft, not to mention red hot) .
The middle of a flame from even a match can be well over 1000degC.
desertstalker is offline Find More Posts by desertstalker
Old Apr 08, 2013, 11:13 AM
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Kevlar or carbon are only secondary in retaining magnets to rotors. The primary retention is the bond between the magnet and the core. Do a bad job on the primary bond and Kevlar or Carbon wrap will just be a waste of time.
FYI CA is just about the worst thing to use in electric motors--it has very poor characteristics when it gets warm.
Steve Neu
sneu is offline Find More Posts by sneu
Old Apr 08, 2013, 01:31 PM
USA, AZ, Tucson
Joined Aug 2008
According to Dupont, Kevlar Aramid fiber is rated to 800 to 900 F and does not melt. It decomposes in that temperature range.
The motor I am attempting to rebuild is an Ecycle Solidslot. The magnets were held in place on the rotor by two stainless steel bands (according the manufacturer). I have pulled the magnets and reset them into place. I have plenty of gap space (the stainless bands are 1.5mm thick). I was looking for a source of uncoated Kevlar or carbon fiber yarn to wrap the rotor to replace the stainless bands. Depending on the thickness, I need 40 to 100 yards.
I could by a Kevlar fishing line, that is normally coated to be slick and stop fraying. Epoxy will not bind it properly.
Old Apr 10, 2013, 03:18 PM
Canada
Joined Nov 2000
Are you seriously believing that wrapping the mags with string is going to be a reliable replacement for oem Stainless Steel bands? Yikes!
Bare is offline Find More Posts by Bare
Old Apr 10, 2013, 04:03 PM
USA, AZ, Tucson
Joined Aug 2008
How many RC brushless inrunner motor companies wrap their rotors in stainless? I thought carbon fiber or Kevlar is the norm.
Old Apr 11, 2013, 06:05 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
What do you call it when it spews Kevlar out like a cotton candy machine at the county fair?
Old Apr 11, 2013, 09:59 AM
USA, AZ, Tucson
Joined Aug 2008
You either were rubbing or hit a temperature were the resin/epoxy binding the Kevlar/carbon fiber failed.
Old Apr 11, 2013, 05:03 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Experimenting with intake/exhaust sizes and got too hot! Believe it or not the windings checked out! It ceased up pretty tight when it cooled
Old Apr 11, 2013, 07:58 PM
sneu's Avatar
Joined Dec 1999
I gave a hint earlier--the primary magnet retention is from the glue joint between the magnet and rotor core. The Kevlar or carbon really is secondary and will fail to keep the magnets in place if the primary bond fails. The only way to really improve things is by having the carbon or Kevlar tow under a lot of tension when wrapping --which is not easy. A stainless steel sleeve can be very good if you can get a shrink type fit where the stainless tube actually is under tension--again not so easy to do in low cost motors.
Steve
Old Apr 12, 2013, 12:02 AM
Joined May 2011
http://www.thethreadexchange.com/miv...FUOe4Aodf3EAMA
seagull10 is offline Find More Posts by seagull10
Old Apr 12, 2013, 03:34 AM
Germany, BY, Gräfelfing
Joined Jan 2003
Good Morning ,
hear what Steve tells you. First find the right glue and second you have to tow the carbon or Kevlar string under high tension. Ther are two ways to do it. 1. to prefabricate a carbontube and slide it with a hydraulic sytem from one side over the rotor .2. to wire a string of carbon or Kevlar under high tow over the rotor and secure the end of the string with this high tension force.Both not easy. And you have to use a Cord/string of carbon or kevlar ,no filament that can not towed with high tension.Alternativ you can also use a Titan wire,that's what we use on our inrunnermotors currently.
Christian Lucas is offline Find More Posts by Christian Lucas
Discussion Has anyone used or considered using magnets to hold a fuse together? TexasAggie FPV Talk 16 Jan 26, 2011 08:29 AM
Question AR6100E with one loose antenna. What should I use to glue/hold it in place? WileCoyote Radios 2 Feb 26, 2008 11:18 AM
Question Placing magnets in a flux ring correctly. SeniorSpan Power Systems 2 Aug 16, 2005 01:24 PM
Best glue to hold GB magnets in place?????? Chuck Power Systems 10 Jul 16, 2004 10:17 PM
How do you hold your batteries in place? Windysurfer Parkflyers 17 Sep 01, 2003 04:33 PM
