Old Apr 28, 2012, 10:01 AM
bimmerland's Avatar
United States, NC, Cary
Joined Nov 2011
Spektrum NIMH battery upgrade voltage difference
Installed 4 Eneloops yesterday and charged them to 5.8v. Verified with screamer and Fluke meter but DX7S info screen shows 5.5. Anybody know why the difference? Thanks
bimmerland is online now Find More Posts by bimmerland
Old Apr 28, 2012, 10:05 AM
grumpy42's Avatar
Canada
Joined Aug 2004
Just the "normal" offset error in voltage readings on the Spektrum radios.
grumpy42 is offline Find More Posts by grumpy42
Old Apr 28, 2012, 10:15 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Because there is a factory acceptance tolerance of +/-0.3V. Yours meets that tolerance. Some radios are dead-on.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Apr 28, 2012, 10:47 AM
United States, FL, Miami
Joined Aug 2009
Did the meters have a similar load (200-300mahish) on the batteries as the DX7S ? I doubt they would hold peak voltage 1.45v a battery while powering anything, heck they wont even be at 1.45v/batt after a few days.
pach is offline Find More Posts by pach
Old Apr 28, 2012, 12:07 PM
Dallas, TX
Joined Jan 2010
I can vouch for that, the one I have here is spot on.
I still find 0.3V a surprisingly large acceptable variation, but I certainly can't complain about mine.
Originally Posted by pach View Post
Did the meters have a similar load (200-300mahish) on the batteries as the DX7S ? .
Probably not, but if a 200mAh load drops your voltage by that much then you have bigger problems.
I'm sure Andy has the right answer, it is just the allowed tolerance.
Telrin is offline Find More Posts by Telrin
Old Apr 28, 2012, 03:15 PM
Joined Aug 2009
A drop from 1.45 a cell to 1.375 a cell under a normal load is perfectly fine. They are called 1.2volt batteries for a reason.
The best way to be sure is to check the packs voltage with a multimeter while the radio is on.
Old Apr 28, 2012, 03:26 PM
Dallas, TX
Joined Jan 2010
A drop from 1.45 a cell to 1.375 a cell under a normal load is perfectly fine. They are clled 1.2volt batteries for a reason.
Obviously they will drop over time, but I wouldn't expect to see that much drop immediately on a freshly charged pack with such a light load.
Personally I wouldn't encourage people to try and check the pack voltage while the radio is on unless they have a pack with an alternate point to take readings from.
Either way, it is academic as we already have the right answer, the radio is not designed to provide accuracy beyond 0.3V so a different reading is generally going to be expected.
Old Apr 28, 2012, 04:35 PM
bimmerland's Avatar
Joined Nov 2011
I just thought that if mine is off by .3 then when my alarm goes off I still have spare capacity. Kinda a good thing.
Old Apr 28, 2012, 04:50 PM
Dallas, TX
Joined Jan 2010
You can adjust the cut-off voltage as well so many feel it would be better to have an accurate voltage reading then decide how conservative you want to be on the cut-off.
Not exactly the end of the world though.
Old Apr 28, 2012, 05:04 PM
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Keep in mind that Eneloops will eventually settle to around 1.3+ volts per cell when fully charged, but fresh off the charger they should be 1.4+ volts per cell.
Wrend is offline Find More Posts by Wrend
Sold new spektrum dx8 2000mah nimh batterynew spektrum dx8 2000mah nimh battery ohsnap Aircraft - General - Radio Equipment (FS/W) 1 Nov 09, 2012 10:13 AM
Discussion Spektrum NIMH battery upgrade bimmerland Batteries and Chargers 13 Apr 23, 2012 05:19 PM
Sold SOLD - NEW Spektrum DX8 Battery - 2000mAh 4.8V NiMH xxrando Aircraft - General - Radio Equipment (FS/W) 2 Mar 28, 2012 10:55 PM
Discussion DX8 and DX7s Battery Voltage Indicator Difference Dodge DeBoulet Radios 47 Mar 06, 2012 08:34 AM
Question Cellpro Safe Adapter & Battery Voltage Difference Protection JimHSoars FMA Direct 8 Nov 05, 2011 07:30 PM
