Old Mar 23, 2012, 10:29 AM
United States, GA, Alpharetta
Joined Feb 2011
Servo problem, please help
Hey guys, so i just replaced a servo on my left aileron. It is the exact same servo as was on it before and the exact servo that is on the right aileron. It maybe a newer version but that is about it. Is there any way to make these line up without moving the rod? The old one lined up perfectly. The push rods are even just not the servo. Thanks!
rc_newbie1991 is offline Find More Posts by rc_newbie1991
Old Mar 23, 2012, 10:35 AM
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
I think that, if you removed the old servo but left the old servo arm attached to the control rod, then you've put the new servo in back to front.
Just undo the servo arm from the servo (small screw on top), undo the control rod holder so the rod can slide freely, then replace the servo arm at 90 degrees on the servo and tighten up the control rod.
If you want, you can just flip the servo around by 180 degrees though
Either way, make sure the servo arm is centred as close to 90 degrees as possible when powered and that the trims are dead zero
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Mar 23, 2012, 10:51 AM
Joined Feb 2011
got it much closer! thanks, Now I cant figure out how the pushrod screw releases. I bought this plane used so did not build it and still learning myself.
Old Mar 23, 2012, 11:00 AM
Joined Dec 2011
Probably an Allen (hex) key? 1.5mm seems common
Old Mar 23, 2012, 11:09 AM
Joined Feb 2011
got it! thanks so much
Old Mar 23, 2012, 11:51 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
You don't want to loosen the pushrod screw. If you rotated the servo as suggested, put it back the way was in the photo. What you want to do is remove the arm from the servo. then with the radio on and the aileron stick and trim centered, put the arm back on the servo in the desired position which should be with the aileron in the neutral position.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Mar 23, 2012, 03:51 PM
Joined Feb 2011
That's what i thought he meant to do and what i actually did
Old Mar 24, 2012, 12:45 AM
Taiwan, 北市
Joined Dec 2010
Better to use the servo with the same brand and same model number as the other one, and be sure to test to see if they all work at the same speed and travel.
Chen
twn Chen is offline Find More Posts by twn Chen
Discussion help with UM T-28 aileron servo, and TBL problem hermanmango Electric Plane Talk 13 May 05, 2012 04:22 AM
Discussion UM T-28 Elev Servo Problem - Help NewarkAndy Micro Ready-to-Fly 12 Jan 20, 2012 01:19 AM
Discussion HELP with Walkera CB180Z servo problem Delta Hot Rod Micro Helis 4 Dec 10, 2011 11:09 AM
Discussion Art tech P-51 servo problem, please help... mercuryrising17 Electric Warbirds 0 Sep 24, 2011 07:19 PM
Discussion Help for servo strange behaviour - how to name the problem JMF11 Radios 5 Sep 08, 2011 07:15 PM
