Old Mar 07, 2012, 09:52 AM
Joined Aug 2006
Question
Programming conventional channels on a Futaba R6203SB
Hello,
Is it possible to program which channels are outputted on the three conventional ports on the R6203SB? for example, I would like to program the receiver to output channels 5, 6 and 7 where it now outputs 1, 2 and 3.
If possible, how do I program which channel I want on which port?
Thanks in advance.
jackheli is offline Find More Posts by jackheli
Old Mar 07, 2012, 03:41 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
According to the manual outputs marked 1, 2 and 3/B are dedicated to channels 1, 2 and 3. It does not mention anything about assignability on the receiver end.
Depending on what transmitter you are using you may be able to assign different functions to channels 1, 2 and 3.
ivanc is offline Find More Posts by ivanc
Old Mar 07, 2012, 06:17 PM
Joined Aug 2006
My 10CH can't assign channels, sadly. Do you know if I can use the Y-Aileron extension cable to extend the s-bus? or do I really need a Futaba hub or terminal box?
Old Mar 07, 2012, 06:26 PM
S.A.D. member
ivanc's Avatar
Joined Dec 2004
You can use regular Y-harnesses with S-Bus only if your servos are S-Bus. A non-S-Bus servo requires an S-Bus decoder.
Wanted Futaba 72Mhz TX, T9cap or t10cap channels Alexhavoc Aircraft - General - Radio Equipment (FS/W) 0 Feb 24, 2012 11:05 PM
Wanted Futaba 72Mhz TX, 6 channels or more nkkromhof Aircraft - General - Radio Equipment (FS/W) 1 Feb 24, 2012 08:44 AM
Discussion All channels on Futaba or just the Throttle? Webheadfred Hoverfly Technologies 7 Dec 08, 2011 12:10 PM
Sold Futaba CGY750 and R6203sb rx combo for sale. Tradhunt Aircraft - Electric - Helis (FS/W) 3 Nov 13, 2011 02:18 PM
Discussion Futaba R6203SB rx: is it really only a 3ch + sbus rx? RCPC Radios 16 Apr 14, 2011 05:17 PM
