Old Jan 27, 2012, 10:45 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I've had a Hershey bar plank that would pulse in flight, but it was deliberate, I could do it on command. No motor at all.
Slowed it up, and it would "pulse" in a semi-stall.
Sparky Paul is online now Find More Posts by Sparky Paul
Old Jan 27, 2012, 12:26 PM
I DS slower than I build!
Cory's Avatar
Idaho Falls
Joined Jul 2006
That's called a hyperstall. It's usually caused by the CG being too far forward but can also be caused by excessive control throw. Plank wings are particularly susceptible. They are sensitive to extremely small CG changes. Just a couple of millimeters change in CG could cause it. What happens is that the elevon stalls repeatedly while trying to pull the heavy nose up. It should happen more easily at slower speeds or during positive G commands, however the slow speed hyperstall will happen at higher speeds the further forward the CG is and thus can happen at fairly high speeds. I could see the prop noise on a hyperstalling wing make a pulsing sound as the airflow through the prop rapidly changes angle.
Cory is offline Find More Posts by Cory
Old Jan 27, 2012, 01:14 PM
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
Originally Posted by Gary Warner View Post
Can you determine if it's an RPM change, or is it change in the sound (without RPM change)?
definitly an RPM sound..just changed motor and ESC so will see what happens today,stay tuned
lectroglide is online now Find More Posts by lectroglide
Old Jan 27, 2012, 01:32 PM
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Cavitation?
Gary Warner is offline Find More Posts by Gary Warner
Old Jan 27, 2012, 02:38 PM
Have you tried actually changing the prop? A small crack in a blade might not be visible, but will affect the rpm as the motor spins up and the blade deforms.
Brandano is offline Find More Posts by Brandano
Old Jan 27, 2012, 03:26 PM
Joined Aug 2006
I think we gotta C rating problem, dont know what it is cuzz the labels worn off but Im sure it isnt anything under 25 ......flew fine for about 2 min into the flight but started acting up shortly after , its also after I changed motor/ESC, so the other gear wasnt the problem........next step try a higher C rating
Old Jan 27, 2012, 03:33 PM
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Originally Posted by lectroglide View Post
I think we gotta battery C rating problem, dont know what it is cuzz the labels worn off, but it didnt do it about 2 min into the flight but started shortly after , its also after I changed motor/ESC, so the other gear wasnt the problem........next step try a higher C rating
That will definitely do it. I had a helo with an inadequate battery C rating. When the battery heated up it lost voltage and the ESC dropped out. Bad mojo - fortunately I was only about six inches off the ground. This battery had no C rating marked on it. I had to go online to the supplier to find out it was only 6C.
HerkS is offline Find More Posts by HerkS
Discussion cox skycruiser porposing baldy1953 Beginner Training Area (Aircraft-Electric) 60 Jun 05, 2014 12:00 AM
Discussion 50" Fifty Inch Flying dollar store wing - First wing creapyd Flying Wings 22 Jan 10, 2012 02:03 PM
Help! flying quaker wing with reed wing tips regal265 Vintage & Old-Timer Designs 5 Nov 27, 2011 10:19 PM
Wanted 48" Flying Wing/Combat Wing Electric wbrannies Aircraft - Electric - Airplanes (FS/W) 8 Sep 30, 2011 08:20 PM
Wanted Big wing...not flying wing sammy Aircraft - Electric - Airplanes (FS/W) 4 Sep 26, 2011 09:47 PM
