Old Mar 25, 2012, 02:29 PM
Alameda, CA
Joined Dec 2006
I think I found a piece of your prop here in California.....
sgomes is offline Find More Posts by sgomes
Old Mar 25, 2012, 03:25 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That's funny!
Lnagel is online now Find More Posts by Lnagel
Old Mar 25, 2012, 03:38 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
I made an error in my calculations. 16 volts would result in only 200+ amps, not 600.
Larry
Old Mar 25, 2012, 03:51 PM
voodoo magic maaan
lukeydukey10's Avatar
United Kingdom, England, Merton
Joined Jan 2011
so, what should I do... get a 1 cell battery?
I think I have been mis sold this motor...
lukeydukey10 is offline Find More Posts by lukeydukey10
Old Mar 25, 2012, 04:15 PM
voodoo magic maaan
Joined Jan 2011
ok, I have looked up the spec...
the rpm is 4550 per volt and 60,000 rpm max
so if running on 4 cells I have over revved it by a nats
If I run on 3 cell it would add up to approx 50,000 so will try that next
Old Mar 25, 2012, 04:21 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Even with one cell you are still looking at over 30,000 RPM which is way too high for most propeller driven airplanes. That might be appropriate for a ducted fan. What you really need is a motor with a substantially lower Kv or you could use one cell and a gearbox with a ratio of 3:1 or 4:1. What specific Kv, battery cell count, or gear ratio depends upon the airplane and how you want to fly it.
Larry
Old Mar 25, 2012, 04:41 PM
voodoo magic maaan
Joined Jan 2011
it is going in a silly quick pylon speed 400 type plane so no gear box required
are we referring to the same types of batteries? I use 2200mah lipo 3 or 4 cell batteries
will try 3 cells tomorrow and report back (damage report)
Old Mar 27, 2012, 10:55 AM
voodoo magic maaan
Joined Jan 2011
have ordered a castle link so i can better program my esc
Old Mar 27, 2012, 03:51 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
The problem isn't over-revving the motor, the problem is the motor pulling too much current. All of the references I've seen show the 1105/1Y to be a 10,0000 Kv, 200 watt motor. I'm not familiar with the S3.2 designation you tacked on, but since you say the Kv is only 4550 I have to assume that is some type of gearbox.
So, working with a Kv of 4550 and a 4.7x4.7 prop it looks like a two cell battery will get you a bit more than 24,000 RPM, 35 amps for around 240 watts and a pitch speed of 90 mph. You will note that the current is substantially below the capacity of the ICE75 ESC and the power is a bit above the motor's 200 watt rating. However, with good cooling you can probably get away with that.
Another thing to note is that the motor current will increase approximately with the square of the battery voltage. So, even though with two cells the current is half of the ESC capacity, doubling the motor voltage by going to four cells will increase the current by a factor of four. That would be twice as much current that the ICE75 is rated for. It's no wonder it wouldn't run with your 4 cell battery. By using 3 cells as you're proposing, the motor current will increase to around 80amps and the motor power will increase to over 800 watts both of which will definitely fry the motor.
Lastely, what you need more than the Castle Link is a watt meter and a better understanding of how motors work.
Larry
For Sale 2 NIP Castle Creation Phoenix-45 Brushless ESC Tommy D Aircraft - Electric - Power Systems (FS/W) 8 Dec 18, 2009 09:39 AM
Sold NIP Castle Creation CC Phoenix-10 Brushless ESC Z06 Tony Aircraft - Electric - Power Systems (FS/W) 0 Nov 15, 2009 12:38 PM
Sold NIP Castle Creation CC Phoenix-10 Brushless ESC Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Oct 25, 2009 10:54 AM
Found New Castle Phoenix ICE 75 (regular version) PatternFlyer Aircraft - Electric - Power Systems (FS/W) 2 Aug 27, 2009 04:29 PM
