Old Oct 14, 2014, 02:11 PM
Florida, USA
Joined Nov 2006
Thrust meter stand
I put together a thrust test stand with stuff I had laying around. The jet sits on the white board that is mounted to the bottom board with high quality ball bearing drawer slides. It moves glass smooth with zero drag. The front of the sliding board is pointed and pushes against a digital scale. I can wind it up hands free and test amps, volts, watts, and thrust. The stock 4 cell Stinger I read 32.3 A, 14.7 V, 460 watts, and 21 oz thrust. It will be interesting to see what the hot set ups are when they arrive. May not mean much in actual flying but I like to tinker.
SlickZERO is offline Find More Posts by SlickZERO
Old Yesterday, 07:06 PM
Calm before the storm
Flyboy81's Avatar
United States, TX, Bullard
Joined Jun 2014
Nice set up! Looks like you might have to subtract the weight of the the base from your calculations. Also there is some sort of friction may be minimal but it still exists even if it is slight. Maybe a digital fish scale type to see what force is needed to get the base moving with the same plane mounted to it.
Flyboy81 is offline Find More Posts by Flyboy81
Old Yesterday, 10:33 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
The weight of the sled would not be factored in the tear weight
turbonut is online now Find More Posts by turbonut
Sold Dr Mad Thrust Test Stand for 50-90mm EDF Systems FL62 Aircraft - Electric - Jets (FS/W) 2 Oct 10, 2014 01:01 PM
Discussion Built vertical thrust stand lokster Power Systems 2 Nov 11, 2013 10:59 PM
Discussion thrust stand/ drag mojambo Power Systems 12 Sep 29, 2013 11:07 AM
Volt Meter, Tachometer, Test Stand, Kyosho Peak Charger and Incidence Meter Doggy Doc Non R/C Items (FS/W) 8 May 28, 2013 06:11 PM
Discussion Safe thrust testing, BP Hobbies thrust stand. DeaninMilwaukee Power Systems 2 Feb 11, 2012 01:01 PM
