Old Aug 30, 2014, 12:24 PM
Joined Aug 2014
Choosing a motor for Crack Yak Mini
I'm in the process of buying a crack yak and the necessary electronics(10g servos. , 10a esc, 2s 7.4v 200mah battery, spektrum nano reciever)I've decided on most of them except for the motor. the recommended motor for this plane is a 14g 2000-2350kv motor(though the necessary servos don't actually exist in the weight recommended so i don't take them too seriously). i'm trying to decide between two motors, one recommended by the guy at my hobby shop- a 1700kv Cobra C-2203/46, and something else i found, a 2300kv Cobra C-2203/34. What would be the real-world difference between these two motors? is there a reason why the hobby shop recommended a motor with a much lower than recommended kv rating?
-also posted in 3d flying; I couldn't figure out how to move it so I duplicated it here.
theblazingak is offline Find More Posts by theblazingak
Old Aug 30, 2014, 12:38 PM
Christian F
United States, CA, Redwood City
Joined Mar 2011
those servos are like double the size you want..... 5g is what i run on my 32" planes
CaliPilot is online now Find More Posts by CaliPilot
Old Aug 30, 2014, 04:22 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
The dual sky motor recommended for this model gives superb flying characteristics, and superb durability. Mine is still running after 18 months learning 3D, dunking in a puddle and many full speed head on ground impacts.
jimbo320 is offline Find More Posts by jimbo320
Old Aug 31, 2014, 03:14 AM
dynodude's Avatar
El Cajon, CA
Joined May 2007
I'm confused. Are you talking about a Crack Yak, or a Crack Yak Mini? For the Crack Yak Mini the DualSky 2212MA25 is a very good motor for this plane. Use it with a 6A ESC. http://www.2dogrc.com/dualsky-xmotor...itional_tabbed
Also, if you are talking about the Mini, 10 gram servos are WAY too big . 4.5g on the ailerons and 3.5 on the rudder and elevator.
dynodude is offline Find More Posts by dynodude
Old Aug 31, 2014, 04:42 PM
United States, OR, Happy Valley
Joined Aug 2012
Love the castle 10a esc quiet and lighter then the th
fooferdoggie is offline Find More Posts by fooferdoggie
Old Sep 01, 2014, 07:21 AM
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
I don't have a mini, but I do have 3 TH models. Two of them have their motor and I'm perfectly happy with them and would recommend them all day long. I love the TH motor on my CYSL. My third has a MF, just because I'm a MF fan.
jk6672 is online now Find More Posts by jk6672
Old Sep 05, 2014, 07:10 PM
Joined Aug 2014
To clarify something, I'm using three 5g servos- I misread the specs originally.
Old Sep 05, 2014, 07:12 PM
Joined Aug 2014
Also, based on some of your recommendations, I'm beginning to think that a larger than recommended motor wouldn't help me at all. I'm still wondering, though, how important is KV rating here?
Old Sep 05, 2014, 08:18 PM
John
jk6672's Avatar
Joined Sep 2012
KV rating is important. The KV rating determines the size prop you need. Flying 3D you need a large enough prop to keep wind over your control surfaces at slow speeds. The prop and kv rating also determine your wattage and amp draw. Improper prop selection could potentially burn out your motor.
Discussion Choosing a motor for Crack Yak Mini theblazingak 3D Flying 1 Aug 30, 2014 10:53 AM
Help! El-cheapo power system for Crack Yak Mini SubaruMike 3D Foamies 9 Nov 17, 2013 06:55 AM
Discussion Cheapo power System for Crack Yak Mini SubaruMike Power Systems 6 Nov 15, 2013 09:24 PM
Found crack yak mini or crack yak microairman1 Aircraft - Electric - Airplanes (FS/W) 0 Nov 08, 2013 03:49 PM
Discussion Crack Yak vs. Crack Yak Mini BrendanH Foamies (Kits) 3 Aug 03, 2013 08:22 AM
