Old Jul 26, 2012, 06:08 AM
Arkansas
Joined Jul 2008
Multicopter motor balancing
How is the best/easyiest way to balance the motors? DJI F550 naza hexa
WyDiablo
WyDiablo is offline Find More Posts by WyDiablo
Old Jul 26, 2012, 08:14 AM
Linux Compatible
machina's Avatar
United States, DC, Washington
Joined Dec 2007
2 second google search.
How to balance a brushless motor (1 min 10 sec)
machina is offline Find More Posts by machina
Old Jul 26, 2012, 08:15 AM
Linux Compatible
machina's Avatar
Joined Dec 2007
Also:
Balance an outrunner (brushless motor) (0 min 27 sec)
balancing motor rotor and open your ears... (2 min 30 sec)
Old Jul 26, 2012, 08:16 AM
mamba max1's Avatar
United States, NC, Durham
Joined Jun 2010
I tried the laser option, but I found balancing by hand was much easier, faster, and actually more effective. Just idle the motors up 1 at a time, and aim for smoothness around your throttle hover area. I use little dabs of hot glue, for weight.
mamba max1 is offline Find More Posts by mamba max1
Old Jul 26, 2012, 08:40 AM
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
I've been doing that too with good success. Just disconnect all but one motor, throttle up with the prop on, vibrations? Put a piece of tape on one side of the prop. More vibrations? Move the piece to the other side. Better? Move it around on that side until you get a smoothly running motor from 0 to 100% throttle. The tape has not fallen off any of the larger props I have, but it can fly off some of the small ones which sit on high kv motors. Use stronger tape on those or something that sticks better.
WiseDuck is offline Find More Posts by WiseDuck
Old Jul 26, 2012, 08:57 AM
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I've always thought that balancing motors is for crazies and obsessive compulsives.
TS00 is offline Find More Posts by TS00
Old Jul 26, 2012, 09:12 AM
Arkansas
Joined Jul 2008
Thanks wiseduck I was trying to balance mine with all 6 motors running and no props. So I was doing it all wrong I see. I was also thinking that if I spooled up with just one motor the power would be too much and I would end up damaging my motor. So disconnect all but one motor and connect the prop to that motor and then do the laser test correct? The laser balancing would be all i could do right now. I don't have anything for the other types of balancing. I did notice that my props were not all the same wieght. They ranged from 12.5 g to 13.1 g and I have fixed that part of the problem.
WyDiablo
Old Jul 26, 2012, 10:44 AM
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
That's up to you. Break props often and you just want to put them on without having to worry too much about balance? Balance the motors. Or if like me, you fly with one set and only a motor failure can break them (I'm confident I won't break any props in a crash that was my fault), balance the setup dynamically, i.e. prop on motor, throttle up, balance it.
I don't think you need a laser. Also, I've never had issues with going full throttle without props on. But I wouldn't recommend it, the centrifugal force can send some of the magnets flying apparently. So just hook up one motor at a time.
As for how to feel the vibrations, I just hold the arm, throttle up and feel the vibrations. It's easy to feel when you're moving in the right direction. On some of my motors on the Y6 I can go from 0 to 100% and I can't feel ANYTHING in the arm, on other motors there are still some vibrations there even after balancing, but that's acceptable to me.
Old Jul 26, 2012, 11:35 AM
Arkansas
Joined Jul 2008
Thanks wiseduck I will try that tonight. I"m use to collective pitch heli's but not multirotors so this is a new ball game to me lolol. The laser trick to me sound neat and I did try that last nite on one arm at a time, but all motors were running. So I don't think that helped to track down single arm vibs.
WyDiablo
Old Jul 26, 2012, 12:37 PM
Tri-City Airport Municipal, Tennesse, United States
Joined Oct 2003
My Quad is all built but I want to balance the motors. The ESC's are soldered to the distribution board. Would it be OK to just unhook the bullet connectors of three motors and run up one motor at a time? the ESC's without the motors attached would still power up due to the distribution board. I didn't know if powering up an esc without motors was harmful.
Jake.
bigjake is offline Find More Posts by bigjake
Old Jul 26, 2012, 01:28 PM
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
@Bigjake...just disconnect the escs at the FC...no need to unhook the bullets unless you really want to ...
SDSURFnGLIDE is online now Find More Posts by SDSURFnGLIDE
Sold Pair of balanced Wicked 4800 motor and matching ESC for twin EDF setup The Don Aircraft - Electric - Jets (FS/W) 4 Jun 25, 2012 07:34 PM
Discussion Multicopter prop balancing PSA Physics_Dude Multirotor Talk 1 Jun 17, 2012 01:09 AM
Discussion Goodluckbuy KK multicopter, one motor not working. joechege Multirotor Talk 0 Apr 23, 2012 02:58 PM
Discussion Multicopter Motor Guide 101 disneytoy Multirotor Talk 5 Feb 25, 2012 11:34 AM
Help! HK Multicopter Control Board - motor doesn't spin - need help Jetro223 Multirotor Talk 2 Feb 24, 2012 02:58 PM
