Old Jun 04, 2012, 01:36 PM
Joined Jul 2008
Turnigy C8085 Dual Controller 6-Phase Rewind
Here's a video of a C8085 outrunnner rewound in a 6-phase, wye configuration.
10 turns (1 meter per tooth) of #14 AWG
36 mOhm phase resistance
162 kV
For testing I am using two ebay "el cheapo" 100A (yah right) ESC's, one for each set of phases. At WOT the no load current is 3.7A @ 23.9V and 3917 rpm (3826 rpm as measured w/ scope). Operation at start-up and low rpm is a bit rough yet it starts to sing above 1500 rpm or so. I should probably verify that I have the controllers set to identical configurations. It's such a PITA to program these with just the throttle...
I kind of messed-up when connecting the phases internal to the motor and as a result I could not get the skirt housing/bearing assembly back in without it interfering (rubbing) with the windings so I am currently running it without that bearing. Up next will be a load test with a 30" prop. I hope it does not fly apart without the skirt bearing. The other outcome might be the controllers flaming-out. In any event it should make for some dramatic video.
Turnigy C8085 BLDC 6-Phase Dual Controller Rewind (4 min 29 sec)
mauimart is offline Find More Posts by mauimart
Old Jun 04, 2012, 03:43 PM
Inspiration
modisc's Avatar
United States, MI, Ann Arbor
Joined Aug 2011
162 kV
http://www.youtube.com/watch?v=LgRK4_4ElhU
I remember that Christian Lucas stated that 6-phase motor will be most powerful system for the 12-N stator. Yet I am also having the concern that how can i find two exactly the same 3-phase ESC to power the 6-phase motor. As you experienced, there might be some synchronizing problems. I am also not sure how better will the 6-phase system be when comparing with a 3-phase motor.
Another interesting thing is that: If I assume the 6-phase motor (I guess it is 2 LRK winding? ) works the same as a 3-phase dLRK motor, two identical 3-phase ESC powering the 6-phase motor with a load (propeller), assuming both ESC is carrying 100A current. To reach the same output power (same speed, same load), a 3-phase motor will be using 200A under the same voltage input?
To note that dLRK windings can actually be viewed as two LRK connected in series. While connecting the two LRK in parallel is not possible, using two separate ESC to power each LRK can be viewed as the two LRK are connected in parallel.
modisc is offline Find More Posts by modisc
Old Jun 04, 2012, 03:49 PM
Inspiration
modisc's Avatar
Joined Aug 2011
By the way, I noticed that you are not using the rear bearing (the large ring bearing), because wires will rub against it?
I rewinded two EMP 5340 (stator size, aka 6374) which is a smaller version of your 8085, while having exactly the same motor design including the bearing system. I hope this thread helps you to solve your issue.
http://www.rcgroups.com/forums/showthread.php?t=1607848
For each motor, I use single wire single direction technique to wind it, and connect them as dLRK and half parallel dLRK, if i remember correctly. To connect them as 2 separate LRK system, your 6-phase system, should not be harder than connecting them as dLRK or half parallel dLRK.
http://www.rcgroups.com/forums/showthread.php?t=1614226
Old Jun 04, 2012, 04:36 PM
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
deleted
lectroglide is online now Find More Posts by lectroglide
Old Jun 04, 2012, 09:45 PM
Joined May 2010
What's the benefit to two esc's? Does it allow for higher current or does it reduce the commutation load on using just one esc?
jkrych is offline Find More Posts by jkrych
Old Jun 04, 2012, 11:33 PM
Inspiration
modisc's Avatar
Joined Aug 2011
I am not very clear but it is definitely not that simple. I think it is something about the magnetic flux density? Hope this thread will attract Christian Lucas attention. I cannot find the subscribe he posted regarding this specific issue.
Old Jun 05, 2012, 10:04 AM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
http://www.rcgroups.com/forums/showp...0&postcount=35
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jun 05, 2012, 01:22 PM
Joined May 2010
maybe its lost in the translation but i cant see any answers-
what relationship would 2 esc play with Kv?
what about amp load and maximum power?
Old Jun 05, 2012, 08:53 PM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Long ago, before we had 5+kW or 300+A ESC, it was a method to use off the shelf controllers and get more power than the largest single ESC available.
The link I posted was what Christian had to say about six phases. I wonder though if Mauimart's motor is six phase or a parallel arrangement.
6 phase offers some efficiency improvement and reduced torque ripple over 3 phase according to some stuff I found online. In a 6 phase motor there is 30 electrical separation between phases compared to 3 phase at 60.
Greg
Old Jun 05, 2012, 09:22 PM
Inspiration
modisc's Avatar
Joined Aug 2011
Greg
That is what i mean by giving this example :
Another interesting thing is that: If I assume the 6-phase motor (I guess it is 2 LRK winding? ) works the same as a 3-phase dLRK motor, two identical 3-phase ESC powering the 6-phase motor with a load (propeller), assuming both ESC is carrying 100A current. To reach the same output power (same speed, same load), a 3-phase motor will be using 200A under the same voltage input? "
Two parallelly "connected" LRK vs Two LRK connected in series (dLRK)
Old Jun 06, 2012, 01:15 PM
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Two ESC means two groups in parallel instead of in serial
So Kv is roughly multiplied by 2
In that example
1) Original C8085 8 turns Delta Kv (announced) 170 rpm/V
x 8 /10 should give 136 rpm/V (10 turns Delta instead of 8 turns)
/ 1.74 should give 78 rpm/V (10 turns Wye, in serial, instead of Delta)
2) Rewound 10 turns Wye : Kv around 164 rpm/V
(compared to 2 x 78 = 156 rpm/V)
Louis
Fourdan is offline Find More Posts by Fourdan
Old Sep 12, 2012, 10:33 PM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Soft start
Do you think using soft start (not the esc soft start) on one set of windings will help the startup issues with BLDC 6 phase motors? Probably a RC time constant will work.
p901P901 is offline Find More Posts by p901P901
Sold 6-TURNIGY Basic 25A v3.1 Speed Controller G-unit Aircraft - Electric - Multirotor (FS/W) 6 Jan 17, 2012 10:18 AM
Sold Turnigy C8085-170 motor MOUNTAINROAD Aircraft - Electric - Power Systems (FS/W) 1 Nov 01, 2011 12:04 AM
Sold Turnigy C8085-170 motor NEW MOUNTAINROAD Aircraft - General - Miscellaneous (FS/W) 0 Oct 31, 2011 08:10 PM
Discussion Turnigy 4240-900 rewind! Doug Bartley Electric Motor Design and Construction 6 Sep 19, 2011 10:33 PM
Discussion How to rewind a 2 Phase brushless motor. MarcAntonio Electric Motor Design and Construction 3 Sep 02, 2010 08:48 AM
